Step 6: Enclosure
A project log for KS Zigbee Gateway
My own Zigbee Gateway with speaker output for realtime audio notifications, with MQTT support and more
cziter15cziter15 03/19/2024 at 14:250 Comments
The 3D-printed enclosure has recently arrived. Unfortunately, I made a mistake and the mounting holes are on the reverse side.
The housing consists of two parts. The larger part can be seen in the photo and the other part is the sliding cover. The printed circuit board is attached to the housing with two screws.
