Othermill Stand.step
Full export of CAD model in STEP file format.
step -
82.40 kB -
01/16/2017 at 22:53
Download
othermill_stands_for_publish.crv
Full layout of all parts on a 4x8 sheet of plywood in Vectric V-Carve format (.crv file)
crv -
19.00 kB -
01/16/2017 at 23:29
Download
back_support_for_publish.svg
SVG file of the back support
svg+xml -
1.33 kB -
01/16/2017 at 23:29
Preview
stand_leg_for_publish.svg
SVG file of the stand leg
svg+xml -
885.00 bytes -
01/16/2017 at 23:29
Preview
Drawing 01 of 06 - Leg.pdf
Drawing of the leg of the Othermill stand. Two of these need to be fabricated. Note that all internal corners do not show fillets so that the dimensions are easy to visualize, but would need to be added.
Adobe Portable Document Format -
35.60 kB -
01/16/2017 at 22:43
Preview
Drawing 02 of 06 - Back Support.pdf
Drawing of the back support piece that fits between the legs of the Othermill stand. Note that all internal corners do not show fillets so that the dimensions are easy to visualize, but would need to be added.
34.48 kB -
01/16/2017 at 23:40
Preview
Drawing 03 of 06 - Base.pdf
Drawing of the Othermill Stand base plate. This is the primary stability pieces immediately below the bottom sliding shelf.
30.53 kB -
01/16/2017 at 22:43
Preview
Drawing 04 of 06 - Bottom Sliding Shelf.pdf
Drawing of the bottom shelf of the Othermill stand. This sits above the "base" on drawer slides.
31.31 kB -
01/16/2017 at 22:43
Preview
Drawing 05 of 06 - Top Sliding Shelf.pdf
Drawing of the top shelf of the Othermill stand. It sits just below the top, between the legs on drawer slides.
31.76 kB -
01/16/2017 at 22:43
Preview
Drawing 06 of 06 - Handles v1.pdf
Drawing of the simple drawer pulls for the top and bottom shelves of the Othermill stand. They aren't necessary at all, but do give it a nice finished look.
31.21 kB -
01/16/2017 at 22:43
Preview
