This morning a Pocketbone assembly arrived at my doorstep.
It was sent in a slightly larger tin along with a small USB OTG to host adapter cable.
The first assemblies looked great up close.
Here is the board inside the original smalls tin.
Still need to figure out a clean way to make holes for the USB and uSD.
And last but not least blinkenlights.
So next step is at home assembly. It'll be a few weeks.
Michael Welling
Jason and co built this one for you ?
Jason put in an order at Circuithub.
Check here for the low volume cost: https://circuithub.com/projects/jkridner/pocketbone-kicad
