All systems go!
A project log for Pocketbone KiCAD
Smalls mint tin sized BeagleBone (KiCAD version)
michael-wellingMichael Welling 03/14/2017 at 03:572 Comments
This morning a Pocketbone assembly arrived at my doorstep.
It was sent in a slightly larger tin along with a small USB OTG to host adapter cable.
The first assemblies looked great up close.
Here is the board inside the original smalls tin.
Still need to figure out a clean way to make holes for the USB and uSD.
And last but not least blinkenlights.
So next step is at home assembly. It'll be a few weeks.
AVR wrote 03/23/2017 at 21:11 point
Jason and co built this one for you ?
Michael Welling wrote 03/23/2017 at 21:15 point
Jason put in an order at Circuithub.
Check here for the low volume cost: https://circuithub.com/projects/jkridner/pocketbone-kicad
