Added STL files for light strip assembly
A project log for Motion-sensor equipped Power LED Driver
A compact board containing an AVR microcontroller that controls a power LED driver which can be activated via motion sensor
roger_archibaldroger_archibald 03/10/2017 at 13:050 Comments
Attached 3 stl files for the end caps that clean up the ends of the Under-Cabinet light strips and drill jigs for drilling the aluminum bits to build up the assembly.
