DreamBlaster X2 MIDI Synthesizer
81 voice Wavetable MIDI Synth PCB with USB and Waveblaster interface
81 voice Wavetable General MIDI Synth PCB with USB and Waveblaster interface I am selling a first batch of PCB&apos;s at <a href="http://www.serdashop.com/DreamBlasterX2" target="_blank">http://www.serdashop.com/DreamBlasterX2</a> Pimp your 286, 286, 486 gaming monsters !!! Or use the usb interface on any newer PC, windows, mac, linux,... even raspberry pi ! Listen to recordings on <a href="https://soundcloud.com/dreamblaster" target="_blank">https://soundcloud.com/dreamblaster</a> , you can hear the difference between the &apos;less is more&apos; preset and the &apos;doomtastic&apos; preset :-) - Waveblaster compatible connector for use on soundcards (such as Soundblaster 16, Audician 32, ESS AudioDrive, Aureal Vortex 2 and many others...) and DIY projects. - Dream 5000 series synth chip with 81 voices polyphony, high quality effects engine - Super low latency - 64mbyte flash for soundbank data - USB MIDI in (Class compliant midi devices) - High quality 24 bit DAC
Here are some recordings of Duke Nukem MIDI files played on X2 :
This review by Phil gives a good overview
The board looks like this :
X2 PCB overview
Portable Network Graphics (PNG) - 196.06 kB - 01/18/2017 at 21:17
Preview
  • 1 × Dream 5504 DSP chip
  • 1 × 24 Bit DAC
  • 1 × 64 mbyte NOR Flash
  • 1 × USB connector
  • 1 × 12Mhz Crystal
View all 8 components
View all 4 project logs
