Adding Noctua Fan to Walksnail Goggles X
Fixing a prototype FPV Goggle heating issue with a 3d printer!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
I was looking for a way to fix the overheating issue with the Walksnail Goggles X and couldn't find a great solution. After much searching, I ended up designing what I consider to be a much better 3D printed fan mount to fix the heating issue.
Fan dimensions: 40x10mm (I used a Noctua 40x10 5v non-pwm)
Link to model: https://makerworld.com/en/models/205845#profileId-225976
Youtube Guide: https://youtu.be/gMbdwEnfKgk
* Please note that I designed this in Bambu slicer and I had trouble exporting the negative spaces into a common file for importing into other slicers.
