## Video
## Structure
The katana has modules of a blade and a grip.
The blade module consists of blade shells, a shaft, and a LED tape. The shells are made with a 3D printer and glued. The shaft prevents the blade module from bending. The LED tape is a 4 mm wide NeoPixel tape and contributes on the thickness of the blade (12 mm).
A Seeed XIAO and a 18650 Li-ion battery are in the Nakago, the inner region in grip of original katana. The shaft is fixed on the Nakago with the shaft holder.
botamochi
Chris Hamilton
Voja Antonic
Akshat Wahi
Philip McGaw
