Two-way Control with Web and Button
This is the simplest application enabling the control of a GPIO line through a hardware button control.
You can expand the functionality of the prev app if you add a hardware button control. Pressing the button will also toggle the state of the GPIO line (LED, relay,...) which is reflected in the LED state displayed in the browser window.
GitHub Repository
Repository page: https://github.com/tibbotech/tps-gpio-tutorials
Clone URL: https://github.com/tibbotech/tps-gpio-tutorials.git
Updated At: Mon Oct 10 2016
  • 1 × Linux TPS3 (LTPS3) board http://tibbo.com/store/tps/ltpp3.html
  • 1 × TBP3 enclosure http://tibbo.com/store/tps/tpb3.html
  • 1 × Tibbit #10 (power supply) http://tibbo.com/store/tps/tibbits.html#/10
  • 1 × Tibbit #18 (power jack) http://tibbo.com/store/tps/tibbits.html#/18
  • 1 × Tibbit #00-3 (2 direct I/O lines with 5V and ground)* http://tibbo.com/store/tps/tibbits.html#/00_3
View all 7 components
  • 1
    Step 1
    Node.js Application
    Add the following code to server.js:
    server.js
    var button = gpio.init("S11A");
    var wasButtonPressed = false;
    button.setDirection('input');
    setInterval(function(){
        // If button is just released...
        if(button.getValue() === 1 && wasButtonPressed === true){
            // ...reads the LED state...
            var ledState = led.getValue();
            //...inverses it...
            if(ledState === 1){
                ledState = 0
            }else{
                ledState = 1;
            //...writes...
            led.setValue(ledState);
            //...and submits to the web app if connected
            if(clients !== undefined){
                clients.emit('tps:state:changed', ledState);
        }else if(button.getValue() === 0){
            // If button is pressed
            wasButtonPressed = true;
    },100);
    To lean more clik here
View all instructions
