Utterance.txtThis is an example utterance to use in the amazon developer skillplain - 36.00 bytes - 01/20/2017 at 22:38 |
Lambda Function.txtThis will be the base code you need to use for an AWS lambda function to work with the alexa skillplain - 1.75 kB - 01/20/2017 at 22:38 |
Interaction Model.txtThis is the base intent code for the interaction model of the alexa skillplain - 155.00 bytes - 01/20/2017 at 22:38 |
