Kinograph
An open-source film scanning machine.
Cultural memory should not be dependent on money. The cost of digitizing reels of film is out of reach for the majority of institutions and individuals. Kinograph aims to provide an affordable alternative by focusing on a "good enough" solution . Our goal is to produce quality scans that are good enough for public exhibition and to prioritize further preservation efforts, all at a cost within reach. The project is a community of contributors and is currently active on the forums: http://forums.kinograph.cc. Current designs and downloads available at http://kinograph.cc
Current State: Work has begun on v2 but is slow due to lack of time and funds. I am actively seeking individuals who are willing to build in parallel, offer technical expertise, and/or contribute skills and time. Areas of opportunity include:
  • OpenCV
  • Material Engineering
  • Electrical Engineering
  • System Architecture (processing unit)
  • Analog Sound capture
  • Software development
  • Post-process scripting (basic scratch and dust removal, auto color enhancement, etc)
Version 2 has the following design improvement goals:
  1. Stronger and more precise motor control with tension feedback
  2. Improved film path for tension control
  3. Completely redesigned gate mechanisms
  4. Digital frame detection (reflective IR and possibly addition of phase-locked loop feedback)
  5. New camera options ( modular design capable of accepting RPi to high-end 4K)
  6. New electronics capable of handling faster speeds and writing directly to dedicated peripherals
Work will continue in fits and starts. Any recommendations for grants, residencies or other sources of support are very welcome!
- Matthew Epler (New York, NY)
Kinograph-InstructablesPDF.pdf
Full build instructions for v1. NOT SUPPORTED OR RECOMMENDED
Adobe Portable Document Format - 2.31 MB - 01/22/2017 at 03:07
Preview
Download
sprocketRoller_20160430.3dm
Rhino file for sprocket roller
3dm - 2.40 MB - 01/22/2017 at 03:01
Download
sprocket.py
Rhino script for adding sprockets to roller
x-python-script - 4.19 kB - 01/22/2017 at 03:01
Download
sprocket_roller.obj
3D printable sprocket roller file
obj - 781.21 kB - 01/22/2017 at 03:01
Download
idle_roller.obj
3D printable idle roller file (no sprockets)
obj - 382.05 kB - 01/22/2017 at 03:01
Download
  • 1 × Film Scanner controlled by Arduino, with DC geared motors and 3D printed rollers.
  • 1 × Custom Frame Extraction Software OpenCV application written in Processing (Java) for detection and extraction of frames from still images of photographed film.
View project log
  • 1
    Step 1
    See the file "Kinograph-InstructablesPDF" in the files section of this page.
View all instructions
Desert wrote 08/01/2021 at 11:26 point
Why using sprockets?
The high end film scanners use a laser. Maybe a LED is possible?
https://filmfabriek.nl
Matthew Epler wrote 08/01/2021 at 15:15 point
Hi there. I'm a huge fan of Filmfabriek's machines! This project page is very outdated. For the most up to date details, you can visit the website: https://kinograph.cc. There you will find links to the YouTube channel, Instagram, Wiki, and Forums pages. Contact me any time. I'd love to talk about the Filmfabriek. We've discussed it several times in the forums with admiration :)
FORART fe wrote 10/01/2020 at 06:41 point
Hi there, great project !
It would be great to establish some kind of collaboration (to promote the open source licensing approach too) with other related DIY projects:
https://hackaday.io/list/175104-diy-film-scanners
Hope that helps/inspires.
H
