Phased Array Sonar
Using ultrasonic transducers to build a phased array!
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Phased arrays are normally very expensive and hard to learn about. This project aims to reduce the barrier to entry to this field with much cheaper ultrasonic transducers. An FPGA is used for high speed signal processing, in combination with an analog front end.
