When main AC power is disconnected from the power supply, the system loses configuration.
Upon AC power connection, the system BIOS is reset and boot takes 1min 40sec.
Usually when such behavior is observed, it is a problem with the coin cell battery.
I have checked the coin cell battery and its connection to the motherboard.
The coin cell voltage is 3.3v and connection to the system is correct.
Is other user of BD770i / BD790i observing similar behavior ? Leave a comment !
I faced this issue directly when secure boot was preventing me from loading custom linux kernel module for the ITE IT8613E system monitoring.
The BIOS seems to reset every time AC power is connected which takes time and discard any custom settings.
By default secure boot is enabled. I would like to also retain custom fan configuration.
Finally managed to RMA my board, the new one does function as intended. No more resets and temperatures are also slightly better during extended full load.
Worth to mention: the revisons printed on the board are the same as with the faulty one.
Experiencing exactly the same annoying issue. Also checked battery and connection. Both are fine. But getting clock and date reset everytime you disconnect the power is extremly annoying.
Did you try to contact support already?
