Genesis
A project log for Print your own PCBs with Laser or CNC or chemicals
Technique to build high quality PCBs in minutes. Also, compare different methods the resolution and ease of use.
quasi-scientistQuasi Scientist 04/18/2024 at 01:250 Comments
It started few years ago when I wanted to build some device it started with a breadboard then it was time to shrink it
This thing is a giant leap, although it was really hard to work with this material
Now I tried building my own using a nail polish/marker and some chemical to etch the copper away
The result was ok but I couldn't reproduce easily and the main problem was the size of wire which with this 'technology' was about 2mm.
