Introduction
In this project “Visitor Counter With Automatic Lighting“, we’ll combine the functionality of an Arduino microcontroller, a 16*2 LCD display, and an IR sensor to create a visitor counter system with automatic lighting. The system will count the number of visitors passing through a specific area while automatically illuminating the room using LEDs if there is at least 1 person in the room.
For full project:
https://electronicsworkshops.com/2024/03/31/visitor-counter-with-automatic-lighting/
Block Diagram
Here’s an explanation of the block diagram for the Visitor Counter with Automatic Lighting system using Arduino, a 16*2 LCD, and an IR sensor:
- The IR sensor detects the presence of visitors passing by.
- Upon detection, the Arduino increments the visitor count and updates the LCD display to reflect the new count.
- Simultaneously, the Arduino triggers the relay module to activate the lighting source providing illumination in the area.
- After a brief delay, the system is ready to detect the next visitor, ensuring accurate counting and efficient lighting control.
Circuit Diagram
Here’s the circuit diagram for your project:
- The IR sensor modules are connected to analog pins A3 and A2 of the Arduino for their data pins.
- The LCD display is connected to the I2C pins of the Arduino (SDA to A4, SCL to A5).
- The LED is connected to digital pin 12 (D12) through a resistor to limit the current.
For full project:
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
OKUNA NGOZI PALMER
Lithium ION
