Wall Mounted Minecraft Sword
Made an enlarged Minecraft sword incorporating RGB lights and an ESP8266 Board.
Public Chat
0 followers
Greetings everyone, and welcome back. Here's something fun: The Enlarged Minecraft Sword was made from scratch using 3D-printed parts and Custom PCBs. The concept was to create a full-sized Minecraft sword with RGB LEDs fitted in order to create a wall light with a Minecraft theme. This 3D printed light is powered by a straightforward ESP12F circuit coupled to a customized RGB LED PCB. Due to the length of the sword, we had to split the model into five parts, which we then put together using nuts and bolts to form the entire sword.
VIDEO-
DESIGN
First, we load the image of the Minecraft sword into Fusion360 and set its dimensions to 550 x 280 mm.
Next, we modeled the sword by tracing its outline, and we then extruded the sword with a thickness of 60mm.
Using the shell command, we hollow out the entire model and then divide it into five sections.
Later, we further divide each section into two parts, which are the lid and the lower base part, which will house the LED board.
We constructed an inner wall inside the lid part so that both parts can be pushed fit together, allowing the lid to fit over the lower half without the need for glue or screws.
We designed parts such that we could mount two sections together with M3 bolts and nuts in order to join several parts together.
The LED board inside the cross guard and blade portion of the sword illuminates the PLA-printed top lid part.
The circuit is housed in the grip portion of the model.
After the model was ready, we exported each of the five lower and five lid components into an STL file, then we used marble PLA for the lower part and transparent PLA for the lid to 3D print all of them.
PCB DESIGN
The main circuit board and the LED board were the two PCBs that we had to model in total for the PCB design.
Let us explore the LED Board first.
The LED Board schematic shows seven WS2812B LEDs linked in parallel, which are intended for lighting the sword's top lid.
The led board was designed so that we could create a single design and use it for every part, eliminating the need to create a distinctive LED board for each one.
Two sides have been added to the schematic: the input side and the output side. The VCC and GND of both sides are connected in parallel. The only pins that are different are the DIN and DOUT pins, which are each connected to a different CON2 pad.
To stabilize the LED, we use 100nF capacitors, each connected to a single LED, so a total seven capacitors were used.
The PCB outline is created using model dimensions that are extracted from the Fusion360 model into a DWG file, which is then imported into our PCB Cad software.
The second board was the ESP12F board.
As the name suggests, the ESP12F Board is a minimal breakout version of the ESP12F Model used in boards like the NODEMCU or other ESP8266 products.
In the schematic, we have added an additional AMS1117 3V version, which steps down the voltage coming from the input side to a stable 3V for ESP12F to function.
Similarly, we have use model from Fusio360 to make the PCB CAD outline.
After preparing the schematic and board files, both parts were sent to PCBWAY for samples.
PCBWAY Service
After completing the PCB design, we export the Gerber data and send it to PCBWAY for samples.
Two orders were placed: one for the main circuit and one for the LED board.
We place an order for a white silkscreen LED board and a blue silkscreen circuit board.
After placing the order, I received the PCBs within a week, and the PCB quality was pretty great. The silkscreen I used is completely random and asymmetrical, so it's pretty hard to make, but they did an awesome job of making this PCB with no errors whatsoever.
You guys can check out PCBWAY If you want great PCB service at an affordable rate.
Minecraft sword Hanging v9.f3d
fusion - 4.40 MB - 04/30/2024 at 16:26
Download
Minecraft sword Hanging v1.step
step - 1.47 MB - 04/30/2024 at 16:26
Download
DIFFUSER03.stl
Standard Tesselated Geometry - 14.14 kB - 04/30/2024 at 16:26
Download
DIFFUSER04.stl
Standard Tesselated Geometry - 10.63 kB - 04/30/2024 at 16:26
Download
04.stl
Standard Tesselated Geometry - 77.91 kB - 04/30/2024 at 16:26
Download
View all 12 files
  • 1
    LED BOARD ASSEMBLY
    • Using a solder paste dispensing needle, we first add solder paste to each component pad, one by one. We're using standard 37/63 solder paste here.
    • Next, we pick and place all the SMD components in their places on the PCB using an ESD tweezer.
    • With extreme caution, we lifted the complete circuit board and placed it on the SMT hotplate, which increases the PCB's temperature to the point at which the solder paste melts and all of the components are connected to their pads.
    We are preparing a total of five LED boards to be used in the Sword Assembly.
  • 2
    CIRCUIT ASSEMBLY
    • After preparing the LED board, we prepare the main circuit board, which starts by adding solder paste to each component pad one by one.
    • Next, we all place the SMD components in their positions using a tweezer.
    • We then pick the whole circuit and place it on the SMT Reflow hotplate for the reflow process, which heats the PCB up to the solder paste melting temperature, reflowing all the SMD components with the PCB.
    • Next, we add the remaining THT components on the PCB which were the DC Barrel jack and the indicator LED.
    • We then soldered their pads using a soldering iron and the Circuit PCB is now complete.
  • 3
    Flashing the ESP12
    Next is the Flashing process of the main circuit's ESP12F Module.
    The usual FTDI board method, which requires connecting a flashing button between GPIO 0 and GND Port, is being used to program the ESP12F Module. During uploading, the ESP12F enters programming mode by long pressing the Flash button first, followed by the reset button.
    Here's an article about programming ESP12F with FTDI Board for more details:
    https://www.hackster.io/Arnov_Sharma_makes/esp12f-standalone-circuit-1de4a7
    Here's the code which was used in this project and its a simple one.
    #define FASTLED_ALLOW_INTERRUPTS 0
    #include <FastLED.h>
    FASTLED_USING_NAMESPACE
    #define DATA_PIN            14
    #define NUM_LEDS            28
    #define MAX_POWER_MILLIAMPS 600
    #define LED_TYPE            WS2812B
    #define COLOR_ORDER         GRB
    CRGB leds[NUM_LEDS];
    void setup() {
      delay( 3000); // 3 second delay for boot recovery, and a moment of silence
      FastLED.addLeds<LED_TYPE,DATA_PIN,COLOR_ORDER>(leds, NUM_LEDS)
            .setCorrection( TypicalLEDStrip );
      FastLED.setMaxPowerInVoltsAndMilliamps( 5, MAX_POWER_MILLIAMPS);
    void loop()
      EVERY_N_MILLISECONDS( 20) {
        pacifica_loop();
        FastLED.show();
    CRGBPalette16 pacifica_palette_1 =
        { 0x000507, 0x000409, 0x00030B, 0x00030D, 0x000210, 0x000212, 0x000114, 0x000117,
          0x000019, 0x00001C, 0x000026, 0x000031, 0x00003B, 0x000046, 0x14554B, 0x28AA50 };
    CRGBPalette16 pacifica_palette_2 =
          0x000019, 0x00001C, 0x000026, 0x000031, 0x00003B, 0x000046, 0x0C5F52, 0x19BE5F };
    CRGBPalette16 pacifica_palette_3 =
        { 0x000208, 0x00030E, 0x000514, 0x00061A, 0x000820, 0x000927, 0x000B2D, 0x000C33,
          0x000E39, 0x001040, 0x001450, 0x001860, 0x001C70, 0x002080, 0x1040BF, 0x2060FF };
    void pacifica_loop()
      // Increment the four "color index start" counters, one for each wave layer.
      // Each is incremented at a different speed, and the speeds vary over time.
      static uint16_t sCIStart1, sCIStart2, sCIStart3, sCIStart4;
      static uint32_t sLastms = 0;
      uint32_t ms = GET_MILLIS();
      uint32_t deltams = ms - sLastms;
      sLastms = ms;
      uint16_t speedfactor1 = beatsin16(3, 179, 269);
      uint16_t speedfactor2 = beatsin16(4, 179, 269);
      uint32_t deltams1 = (deltams * speedfactor1) / 256;
      uint32_t deltams2 = (deltams * speedfactor2) / 256;
      uint32_t deltams21 = (deltams1 + deltams2) / 2;
      sCIStart1 += (deltams1 * beatsin88(1011,10,13));
      sCIStart2 -= (deltams21 * beatsin88(777,8,11));
      sCIStart3 -= (deltams1 * beatsin88(501,5,7));
      sCIStart4 -= (deltams2 * beatsin88(257,4,6));
      // Clear out the LED array to a dim background blue-green
      fill_solid( leds, NUM_LEDS, CRGB( 2, 6, 10));
      // Render each of four layers, with different scales and speeds, that vary over time
      pacifica_one_layer( pacifica_palette_1, sCIStart1, beatsin16( 3, 11 * 256, 14 * 256), beatsin8( 10, 70, 130), 0-beat16( 301) );
      pacifica_one_layer( pacifica_palette_2, sCIStart2, beatsin16( 4,  6 * 256,  9 * 256), beatsin8( 17, 40,  80), beat16( 401) );
      pacifica_one_layer( pacifica_palette_3, sCIStart3, 6 * 256, beatsin8( 9, 10,38), 0-beat16(503));
      pacifica_one_layer( pacifica_palette_3, sCIStart4, 5 * 256, beatsin8( 8, 10,28), beat16(601));
      // Add brighter 'whitecaps' where the waves lines up more
      pacifica_add_whitecaps();
      // Deepen the blues and greens a bit
      pacifica_deepen_colors();
    // Add one layer of waves into the led array
    void pacifica_one_layer( CRGBPalette16& p, uint16_t cistart, uint16_t wavescale, uint8_t bri, uint16_t ioff)
      uint16_t ci = cistart;
      uint16_t waveangle = ioff;
      uint16_t wavescale_half = (wavescale / 2) + 20;
      for( uint16_t i = 0; i < NUM_LEDS; i++) {
        waveangle += 250;
        uint16_t s16 = sin16( waveangle ) + 32768;
        uint16_t cs = scale16( s16 , wavescale_half ) + wavescale_half;
        ci += cs;
        uint16_t sindex16 = sin16( ci) + 32768;
        uint8_t sindex8 = scale16( sindex16, 240);
        CRGB c = ColorFromPalette( p, sindex8, bri, LINEARBLEND);
        leds[i] += c;
    // Add extra 'white' to areas where the four layers of light have lined up brightly
    void pacifica_add_whitecaps()
      uint8_t basethreshold = beatsin8( 9, 55, 65);
      uint8_t wave = beat8( 7 );
        uint8_t threshold = scale8( sin8( wave), 20) + basethreshold;
        wave += 7;
        uint8_t l = leds[i].getAverageLight();
        if( l > threshold) {
          uint8_t overage = l - threshold;
          uint8_t overage2 = qadd8( overage, overage);
          leds[i] += CRGB( overage, overage2, qadd8( overage2, overage2));
    void pacifica_deepen_colors()
        leds[i].blue = scale8( leds[i].blue,  145);
        leds[i].green= scale8( leds[i].green, 200);
        leds[i] |= CRGB( 2, 5, 7);
    This code is for creating a mesmerizing animation called "Pacifica" using addressable WS2812B LEDs with the FastLED library, which you need to install first before trying this code.
    The animation creates a dynamic and visually appealing effect, resembling ocean waves with changing colors and brightness.
View all 8 instructions
