OK, so these are my first uninformed baby-steps towards realizing my overly ambitious world-dominating bench/lab power supply, but i am old enough to handle people laughing at me or calling me an idiot, so this will not be a tested and verified recipe for how to build a power supply, but rather document my progress or failures through my learning process and perhaps someone can at least learn how not to do (I will make sure to add a section in my last will and testament requesting someone to post a warning here if this ends up causing my early demise).
Premise:
- Safety first - while building and when using.
- ATX PSUs are made for ATX cases, use it!
- Minimize reinvention, if there is a part that is ready to buy, buy it and use it!
- Push the boundaries of my knowledge to expand them, don’t step over them!!!
- Avoid unnecessary investment where possible
- Use low-cost sources (Aliexpress/Banggood/ebay)
- If possible, re-use my beautiful analog Conar Instruments gauge (mostly for style points).
Desired Features/Wish list:
- 220v/50Hz input
- Big, bright, obvious power indicator LED - Thanks to Martin
- Touch screen display
- Six output channels + USB power outputs:
- 3.3v
- 5v
- 12v
- -12v(?)
- 0-30V/5A Variable CC/CV
- USB 5v power-only ports for convenience (possibly with V/A display)
- Individual breaker/switch for each output
- Rotary encoders for controlling variable output - thanks Martin for the suggestion!
- Current limiting
- WiFi Connectivity
- Displays and logs current (+Min/Max)
- Displays and logs voltage (+Min/Max)
- Color coded outlet posts /displays
- Per-outlet V/A display
- Temperature sensors
- Variable Fan Cooling controlled by temp sensors and MCU
- Use ATX power input with fuse and switch (if within specs)
- 4-Channel 2.5V/7.5V/5V/10V Voltage Reference
- Real time clock (on Nextion display) and online NTP sync
Nice to have:
- Plug-n-play modular (drive bay enclosures?) - possibly in the future if i find a cheap case with 4-6 large drive bays.
- Tentative: Timer/shutoff per-channel (for long running and remotely monitored labs)?
- Display/Log Watts, Watt Hour
- Measuring μA
Open points:
- Selectable and bypassable automatic reset/polyuses for each channel? - Ref. Dangerous Prototypes ATX breakout board.
- Use OpenDPS and a DPS5005 for the variable power?
Considered and removed/rejected:
- Integrated residual-current circuit breaker(?) - adds no protection here - advised against by Martin and Chris.
- Timer shutoff for whole power supply - inconvenience, may interrupt work - advised against by Martin and Chris.
References and inspiration:
Peter Oakes:
https://hackaday.io/post/13498
bjorn
Makertronika Labs
Keith
Hi Martin,
Thank you for some great input!
- Rotary encoders will be added to the list, i have had them (or ten-turn pots) in mind, but wasn't sure how i would implement the control using them. Good input.
- self resetting fuses; I planned to use them on the fixed voltage outputs, but not on the CC/CV variable voltage part, but maybe i'm thinking wrong (it happens a lot). I got this idea from the Dangerous Prototypes ATX breakout board which uses "a 1.25 amp resettable polyfuse on each supply help protect your project from the full current of ATX supply." i did plan to have a switch or bridge to select different fuses/amp levels or bypass them, but i might need to rethink that then.
- on the timer function; very valid point, i figured that it would be good to have because i am forgetful and at times wont visit the lab for weeks, so distrustful of my own capabilities and quality of my work, i thought i would add the timer and the residual-current circuit breaker. I can always use power plug versions of these at the outlet until i build up the confidence. :)
- Single point mains connector; I planned to use the ATX for this as it has built-in fuse and switch, and it is the natural way to power a case. It does mean i will need to open it up, and caution - as mentioned in the above point - made me think. Then again, its not the first time i rewire a 220v device, and if i connect the second PSU right at the socket on the inside, it shouldn't push the ATX PSU ratings in any way, right?
I might still consider optional timer and/or remote on/off functionality for some of the outputs, controlled by MCU, as a way of controlling remote monitored/logged experiments (my lab is in the basement and I am lazy :) ). Mains input to the power supply i might just put on a zigbee/wifi switch with enough capacity.
Excellent input guys, i really appreciate it!
All the best,
bjorn
