Documentation Update
A project log for Integrated HUB - Ethernet, USB, RS232
Ethernet Switch, USB HUB, USB-Ethernet and USB-RS232 Adapter
jesse-farrellJesse Farrell • 11/04/2024 at 15:59•0 Comments
I did a big documentation push over the weekend and added 3000 words to my hardware architecture spec document. If your interested in the details of this project, or are looking to do something similar I recommend you take a look in this projects attached documents.
Note, its still technically unreleased since I need to add sections for creepage and clearance, validation and likely some other sections which don't exist yet.
