PYcARD (Jean-Luc) - Python+Arduino in card shape
SamD21 card development platform
with 22x5 led matrix display,
sd card, battery, environment sensors
Starting from
$47.07
bobricius has 569 orders / 40 reviews
Ships from Sarisske Dravce, SK
- wallet development platform :)- badge / wrist band holes ( wearable )- compatible board with micropython (CircuitPython) - extra thin Display from here https://hackaday.io/project/18014-5-alphabets-charlieplexed-matrix-display-22x5- I2C header for extra sensors ( TOL distance, pressure, compass, gas )- DS3231 > precise RTC- SHT21 > temperature, humidity- BME280 > temperature, humidity, atmospheric pressure ... maybe BME680 soon- RGB led- Power led- 3+1 buttons- micro USB or PCB USB- sd card reader - CR2032 battery optional power supply or DS3231 backup- buzzer- Enig gold 2mm PCB boardEasy program in python, just plug in to USB, you can see mass storage device with .py filesjust change program in notepad ... amazing simple.Or write sketch in arduino IDE :)
main.py
Test script to flash onboard RGB led
py - 220.00 bytes - 03/07/2017 at 14:48
Download
bom.txt
bom exproted
plain - 7.52 kB - 03/06/2017 at 23:08
Download
PYcARD.sch
Schematic
sch - 1007.21 kB - 03/06/2017 at 22:33
See BOM
Download
PYcARD-RTM.brd
Board with display for factory
brd - 329.05 kB - 03/06/2017 at 22:33
Download
firmware.bin
adafruit-circuitpython-arduino_zero-0.9.1.bin
octet-stream - 180.10 kB - 03/06/2017 at 22:33
Download
View all 10 files
  • 1 × micro SD reader
  • 110 × Display led blue 0603
  • 1 × Power led blue 0805
  • 1 × RGB led 3528
  • 5 × 100n 0603
View all 20 components
View all 2 project logs
  • 1
    Step 1
    Assembly board ...
    solder all components
  • 2
    Step 2
    Burn bootloader ...
    it is easy, just connect atmel ICE,
    run arduino IDE and click on ...Burn bootloader
    Now you have Arduino zero compatible board, you can upload display test demo
  • 3
    Step 3
    Install Circuitpython ...
    Download circuitpython release
    rename file to firmware.bin
    press twice reset button to activate bootloader
    run this command
    bossac -e -w -v -b firmware.bin
    press reset ... now you have new drive in computer ...
    copy main.py file ... RGB LED start red flashing :)
View all 3 instructions
Ezequiel wrote 06/03/2017 at 01:19 point
where did u buy the atsamd21g18?
bobricius wrote 06/03/2017 at 06:15 point
mouser, farnell, tme ...
Jacob Sayles wrote 02/25/2017 at 19:44 point
People have asked us to create a wearable biometric data gathering device (see our philometer project) and this board would be really fun to build around.  Nicely done!
Kushal wrote 02/23/2017 at 14:22 point
Is there any description for how to make this project ??? I can't understand how can we make it .
bobricius wrote 02/24/2017 at 13:14 point
Boards on way, soon as posible I assembly and post more info.
fdufnews wrote 02/19/2017 at 09:27 point
Very interesting project.
Have you any idea of how much this board will cost?
bobricius wrote 02/19/2017 at 09:50 point
about 100$ 20pcs ....20$ for 2mm, 20$ ENIG, 25$ steel stencil (soldering lot of led without reflow is suicide ) and rest is for boards. Boards shipped and awaiting soon delivery :)
oshpark wrote 02/07/2017 at 18:32 point
Love the name :)
Riley wrote 02/04/2017 at 23:39 point
What is this ridiculous site format?  Can't make head nor tail of it...
Thinkerer wrote 02/24/2017 at 04:07 point
Ridiculous site is (and always has been) ridiculous.  Can't figure out if it's the summer intern or a big committee to blame.
