Indirect branch
A project log for YGREC32
because F-CPU, YASEP and YGREC8 are not enough and I want to get started with the FC1 but it's too ambitious yet.
yann-guidon-ygdesYann Guidon / YGDES • 09/20/2024 at 05:17•0 Comments
The current ISA draft is very incomplete... it is characterised by a very tight and strict (almost crippling) branch system focused on speed and safety. But this is insufficient in practice and a better compromise is required and "indirect" jumps/branches are required (or else coding can become miserable).
An indirect branch can branch to one in a multitude of addresses that are stored in an array/table, to implement switch/case or other structures.
To prevent arbitrary jump target injections, instruction addresses can only be located in instruction memory, which is considered "safe" (to a certain degree) because it is constant and immutable. The compiler is responsible for the validity of the contents of this space.
Today's progress is the allocation of an opcode range, next to INV=0xFFFFFFFF, to hold indirect branch addresses. Instruction addresses are 24 bit long so the instruction prefix is 0xFE followed by the address. This prefix still decodes as INV though because it is NOT an instruction but a pointer so executing it must trap.
Also this is NOT a JMP instruction because the pointer should only be handled by a dedicated "indirect branch" opcode. However, JMP could be allocated as a neighbour 0xFD opcode to merge some logic/function. So the opcode value works like a sort of "indirect branch target validation tag" or similarly found in recent ARM architectures.
There are still a number of issues to resolve though :
Food for thought...
