Perverting RV
02/25/2025 at 00:22 • 0 commentsLet's talk about RiscV.
In the 80s and 90s its design principles and implementations would have been absolutely wonderful. But we're in 2025 and the RISC-V architecture is ... a big disappointment on many levels. I won't go into details why but the simple fact that I design YGREC32 will prove some of my points.
The problem is : nobody expects YGREC32 or F-CPU, everybody "wants RISC-V", yet is unable to say why, apart from "that's what everybody else wants". And they don't want to pay an ARM or a LEG for a license. And there are tons of "free cores that implement it already". Just don't look at the details, or the favourable comparisons with x86 start to vanish.
Now what can I do ?
My Grogu is determined to design a RISC-V SoC and there is no way to stop him, the Force is so strong with him, but I fear he will corner himself sooner or later, trying to oblige to "market pressure" and despite my attempts, I'm unable to help him on that outdated architecture. Damnit, I'm too old and cranky to even feel comfortable using a 6809 or even 6309...
But the "baseline" RV arch is designed on extensibility, leaving the 2 LSB cleared for "later use", and the base opcodes have MSB=00. Meanwhile, Y32 has 3 pipelines, each could have one of of the remaining MSB combinations:
- 00 : RV
- 01 : Y32-control/stack
- 10 : Y32 data pipeline / glob0
- 11 : Y32 glob1
So with some work, it would be possible to "graft" Y32 over a RV32 core, maybe as an "accelerator" or something, or a "bi-mode" processor, and later jettison RV32, or even worse : reintegrate certain Y32 features back into the RV32 core. I can hear Dave Patterson howl at the moon from here.
Restructuring the instruction bundles
12/07/2024 at 04:01 • 0 commentsI was very satisfied with my instruction-to-pipeline mapping, with one opcode for each globule followed by a control instruction. And today my ideas wandered somewhere else : what about the predicated instructions ?
Due to the still high cost of dealing with branches, it would be awesome to be able to simply "selectively skip" a (small) number of instructions. And this creates a whole lot of new issues, but this is required to reduce the overhead of small branches, due to the still small number of branch target slots.
First, how many instructions is it possible to skip ?
I'd say : not more than a cache line. That's 8 instructions, or 3 cycles at full bandwidth.
This can create some atomicity issues, particularly during decoding. And this also reshuffles the instruction bundle with the predicate in the first/leading position instead of the last.
The point of predication is to conditionally "abort" instructions by preventing the result(s) from being written back to the register set. Otherwise, we're entering the "shadow register hell" and blow up the core's complexity. This also means that predicated instructions can not reuse earlier results from the same predicate. This also implies that control instructions can't be predicated, and maybe no more than 4 ALU operations shadowed (2 cycles get us to the ALU result, it's time to make sure the result is written back, or not).
OTOH this gives just enough time for the control circuits to fetch the relevant condition and propagate the decision.
BTW the predicated sequences work in a way similar to the "critical section" instruction so there is something to explore deeper here.
Data Stack protections
11/19/2024 at 03:34 • 0 commentsYGREC32 has several features that I described in recent articles, in particular is can "shield" the bottom of the stack from read and/or write. This means that a caller can prevent callees from extracting or altering its own state.
There is a series of articles that cover the matter:
Les « tourments de la monopile », ou le « Single-Stack Syndrome »
Une histoire des piles et de leur protection
Une (autre) pile matérielle pour le modèle bipilaire
Au-delà de la fonction : libérez tout le potentiel de la pile de contrôle !
Recently I was thinking about what happens when a function returns but its data remain "on the stack" : the next call can scan these data and extract information.
The usual approach is to flush the data on exit. This is wasteful and new functions usually start by initialising/flushing their stack frame anyway. So this would be required only for "secure" functions, but this is another slippery slope, since "what needs to be secured ?"
So here is the proposal. YGREC32 already has the read_shield and write_shield ancillary registers, that trap when reading or writing below said addresses. Their values can be updated during call and return, thanks to the protected control stack. So why not make something similar but for the addresses above the stack frame ?
The behaviour is different though :
- reading above the given address will return 0 (or some canary value)
- writing will work and replace the old value in the cache. This will also invalidate the corresponding cache line, except for the written word.
This way :
- writing to the top of the stack will not trigger a cache read even
- reading above the stack top does not leak information from previous calls.
- all function calls are safe and fast.
Of course this requires cooperation with the data cache...
Globule symmetry
10/27/2024 at 21:35 • 0 commentsIt seems I'll have to change, adjust, adapt my model of the globules because of the memory access patterns.
The "symmetrical globule" idea is great because it's simple, efficient, easy. The functions can also be merged during one cycle by issuing an instruction pair to perform operations that are more complex than what a single instruction could do alone : 2R2W or 3R1W instructions such as
- addition with carries,
- multiplication,
- division,
- barrel shift/rot,
- bit insert/extract,
- MAC maybe...
Each globule is dumb and designed for speed, which limits their functionalities a lot, but new features naturally appear when they are coupled. And this breaks the symmetry, in particular for scheduling and the instruction decoder/dispatcher.
The original idea was very simple : instructions are grouped in 3 consecutive words, or less, that follow the following pattern G1 G2 C or any substring, so overall we can have the following sequences:
G1
G2
G1 G2
G1 G2 C
G1 C
G2 C
C(that's a total of 2³-1=7 combinations, and not 8 because the empty set does not exist).
But the pairing breaks this nice little clean system. A pair would be a special case of G1 G2 where the first opcode signals a pair, which constrains the second opcode in the pair. Each globule provides their operands and then both can receive a result, often after another cycle (or more depending on the operation).
But due to requirements in orthogonality, you may want your operands and results to go almost anywhere, right ? So you may end up with these sequences:
P1 Q2
P1 Q2 C
P2 Q1
P2 Q1 Cwhere P is the first opcode of a pair, and Q its "qompanion". And you see that the order of the globules can now be swapped! You still have a requirement to have certain operands and results in separate globules but inhibiting P2 Q1 would add too much stress on the register allocator, I think.
This also increases the number of opcode types : we have G, C, P and Q now. So the opcode requires 2 bits.
Also the operands of the Q opcodes are implicitly complementary to the leading P opcode, so there is no need to distinguish Q1 and Q2, it's possible to save a couple of bits but I doubt it's worth the effort. Let's keep both for now.
The system starts to break down when confronted to the constraints of accessing memory through the A/D register pairs. It's not a new system since the CDC6600 (and family) uses dedicated address and data registers as well, however 3 address registers are used for writing and 5 are for reading so the semantic is clear:
- Write to a write register, and any write to the corresponding data register will trigger a memory write cycle.
- Write to a read register and the read cycle is immediately triggered.
On the YASEP/Y8/Y32, the A/D pairs are not committed, which allows read-modify-write sequences. It's all fine with the YASEP (16-32) and Y8 because the memory is tightly coupled and usually has one level. Triggering a read cycle upon register write is not an issue. However Y32 has more latency, in fact it's meant to deal with several cycles, so if you only want to write to memory, updating the A register could trigger a cache miss and a long, painful fetch sequence...
... tbc ...
How fast can it run ?
10/27/2024 at 17:46 • 0 commentsI just came across this very recent measurement on the latest Intel 2xx series chiplet-based CPU. It's interesting because it gives a modern view of the best performances and latencies the bleeding edge can achieve.
See the source there:
The main memory is still slow, hovering around 100ns, nothing new here. The quoted 130ns is from a misconfigured motherboard and an update brings it to a less sluggish 83ns, which has immediate effects on the performance. Further architectural enhancements can only come from the usual methods here : larger buses, more channels, more banks, tighter controller integration...
The interesting parts here are the latency ratios of the cache levels. L2=5.8×L1, L3=L2*5.6
Oh and that system can clock to 5.7GHz, so one L1 hit takes 4 clock cycles, and God knows how many instructions per cycle one such core can execute in this time.
An interesting outlier is this datapoint : L1 copy is faster than read or write. Some mechanism is at work here, probably "locality" or "streaming", with a large bundle/buffer that groups words and aligns them or something.
Note that 5.7GB/s at 5.7GHz amounts to one byte per cycle. That's decent but not much.
The YGREC32 is not designed to work with the fastest silicon processes and most expensive foundries but the above numbers are rough estimates for the ratios that will be encountered in a "good enough" implementation. The point is that the architecture must be scalable and requires only little adjustment during shrinking.
This first thing we can conclude is that without L3 yet still following the "6× per level" rule-of-thumb, the CPU can't run much faster than one GHz or so. More or less, it's the L3 that enables the latest CPU to reach and keep running abot (say) 1.5GHz.
The other lesson is that memory latency is really, really important. An in-order CPU spends a lot of time waiting for data, leading to ever-increasing cache sizes and levels, as well as very deep out-of-order cores. Increasing the number of cores is another aspect, and Simultaneous MultiThreading helps with keeping the cores busy.
The worst problems come from OOO and the "solution" for this, explored in Y32, is to explicitly prefetch. The data are already playing the prefetch game since the D/A register pairs implicitly work like "reservation stations". Y32 has 16 such stations for data and 8 for code. This is comfortable maybe up to 500MHz or so. Faster clocks will require SMT, which is easy with Y32 but more than 2 threads will significantly bloat the core's area, so more cores become necessary.
OK, let's have two cores with 2× SMT for a decent speed. Now we hit two major walls: the FSB bandwidth wall gets hammered and there is probably not enough parellelism in the workload to occupy the cores. In interactive workloads, the separate cores act as local caches for the threads, since there is less space to move around, load to and spill from the caches. There is an incentive to keep as much data as possible onchip and swap only infrequently used data offchip. Speaking about swapping, this means that data blocks are more or less treated at the page level, or somesuch coarse granularity to increase efficiency, but this also increases latency by preventing multiplexing.
So overall, the clock range for Y32 would be from about 100 to 500MHz without extra architectural features. Out of the box, it could handle up to 16+8+2 concurrent memory transactions (data, instructions and stack) per thread. That's good but can only be exploited by good code, made by good compilers that can think beyond the old load-store paradigm.
The limiting factor will be the number of "reservation stations" (D/A registers and eBTB entries). FC1 will double them but that might not be sufficient, yet there is only so much space in an instruction word. "Register windows" and remapping of addressable resources will become necessary to push beyond the gigahertz hill.
Indirect branch
09/20/2024 at 05:17 • 0 commentsThe current ISA draft is very incomplete... it is characterised by a very tight and strict (almost crippling) branch system focused on speed and safety. But this is insufficient in practice and a better compromise is required and "indirect" jumps/branches are required (or else coding can become miserable).
An indirect branch can branch to one in a multitude of addresses that are stored in an array/table, to implement switch/case or other structures.
To prevent arbitrary jump target injections, instruction addresses can only be located in instruction memory, which is considered "safe" (to a certain degree) because it is constant and immutable. The compiler is responsible for the validity of the contents of this space.
Today's progress is the allocation of an opcode range, next to INV=0xFFFFFFFF, to hold indirect branch addresses. Instruction addresses are 24 bit long so the instruction prefix is 0xFE followed by the address. This prefix still decodes as INV though because it is NOT an instruction but a pointer so executing it must trap.
Also this is NOT a JMP instruction because the pointer should only be handled by a dedicated "indirect branch" opcode. However, JMP could be allocated as a neighbour 0xFD opcode to merge some logic/function. So the opcode value works like a sort of "indirect branch target validation tag" or similarly found in recent ARM architectures.
There are still a number of issues to resolve though :
- Range validation: how do you ensure that the address array is correctly indexed, with no out-of-range access ? I guess that the prefetch instruction must include a maximum index somehow, probably limited to 256 entries ?
- Multicycle operation: the prefetch must first fetch the instruction memory for the pointer then do another fetch cycle to get the actual instruction. That's not RISCy...
Food for thought...
more details.
08/17/2024 at 01:44 • 0 commentsThe Y32 architecture is mostly divided in four essential blocks, each with the dedicated memory buffers:
- Glob1 (with dCache1)
- Glob2 (with dCache2)
- eBTB (with iCache)
- control stack (with stack cache)
A 5th block (with no memory access or array) processes data for multi-cycle and/or more than 2R1W operations (Mul/Div/Barrel shifter/...)
Yet the YGREC32 is a 3-issue superscalar shallow-pipeline processor. This directly dictates the format of the instructions:
- MSB=0 for "operations", that is: opcodes delivered to the globules to process data. Note: opcode 0x00000000 is NOP. The following bit addresses the globule, so there are 30 bits per instruction.
- MSB=1 is the prefix of the "control" opcodes, such as pf/jmp/call/ret/IPC/spill/aspill/... This affects the control stack as well as the eBTB (sometimes simultaneously). Note: 0xFFFFFFFF is INV.
The globules are very similar to the YGREC8 : a simple ALU (with full features, boolean, even umin/umax/smin/smax), 16 registers with 8 for memory access, and a 32-bit byte shuffle unit (aka Insert/Extract unit, for alignment and byteswap: see the #YASEP Yet Another Small Embedded Processor's architecture).
It must be small, fast : Add/sub, boolean and I/E must take only one cycle.Complex operations are performed by external units (in the 5th, optional/auxiliary block) that get read and write port access with simultaneous reading of both register sets to perform 2R2W without bloating the main datapath: multiply, divide, barrel shift/rotate... The pair of opcodes get "fused" and can become atomic, but could also be executed separately.
Fused operations require an appropriate signaling in the opcode encoding.
For context save/restore, it would be good to have another, complementary behaviour, where one opcode is sent to both globs (broadcast).
It is good that control operations can be developed independently from the processing operations, though sharing the fields (operands and destinations) is still desired.
Both globs are identical, symmetrical, so there is only one to design, then mirror&stitch together.
Each glob communicates with the other through the extra read port (the register sets are actually 3R1W), and are fed instructions from the eBTB. The only connection with the control stack is for SPILL and UNSPILL, using the existing read & write ports. Each glob provides a set of status flags, which are copies of the MSB and LSBs of the registers (plus a zero flag). Hence some of the possible/available conditions are
- LSB0
- LSB1
- LSB2
- MSB
- Zero
The multiple LSB conditions help with dynamical languages that encode type and other ancillary values in the pointers (including #Aligned Strings format ). MSB can be a proxy for carry.
Oh and yes, add with carry is a "fused"/broadcast operation that writes the carry in the secondary destination.
a first basic module.
07/03/2024 at 10:32 • 0 commentsHere is a first attempt at writing a module that just prints "Hello world!".
It shows the basic structure of a module as well as the IPC/IPE/IPR instructions that allow modules to call each others.
; HelloWorld.asm Section Trampoline ; init: Entry 0 IPE ; nothing to initialise IPR ; run: Entry 1 IPE ; no check of who's calling. jmp main Section Module main: ; get the number/ID of the module that writes ; on the console, by calling service "ModuleLookup" ; from module #1 set 1 R1 set mod_str R2 IPC ModuleLookup R1 ; result: module ID in R1 ; write a string of characters on the console ; by calling the service "WriteString" ; in the module designated by par R1 set mesg_str R2 IPC WriteString R1 IPR ; end of program. Section PublicConstants mod_str: as8 "console" mesg_str: as8 "Hello world!"
I'm a bit concerned that the IPC instruction has a rather long latency but... Prefetching would make it even more complicated, I suppose.
eBTB v2.0
07/03/2024 at 01:13 • 15 commentsThe last log introduced a modified, explicit Branch Target Buffer. It has evolved again since then and is taking a new life of its own...
As already explained, it totally changes the ISA, the compiler strategy, the coding practices, almost everything, but it is able to scale up in operating frequency, or with CPU/Memory mismatch, provided the external memory works with pipelined transactions. The new ISA exposes some of this and lets the compiler handle parts of the overlapping of prefetches.
So the jump system works with two phases :
- The program emits a prefetch operation: this associates a jump address to a fixed ID. The visible ID is 3 bits, there can be up to 8 simultaneously ongoing prefetch operations. For each ID, there is one 8-instruction cache line that is stored close to the instruction decoder, for immediate access. It usually takes several cycles to fetch the desired line and store in in the BTB.
- The actual "jump" instruction selects one of these 8 lines (with the 3-bit ID in the instruction) and checks the (possibly complex) condition. If the condition is verified, the selected line is chosen as source of instructions for the next cycle, and the PC starts to prefetch the next line(s) in its double buffer.
You can see this system as exposing a register set dedicated to instructions addresses. Each register is a target, so let's call them T0 to T7. You can only perform an overwrite of these registers with a prefetch instruction, or a "loopentry" instruction for example : there is no fancy way to derail the CPU's operation.
Each line has one of 4 states:
- absent/invalid
- fetching/checking
- failure/error/fault
- valid
This system mirrors the already studied mechanism for accessing data memory, but the BTB is much more constrained : Each data fetch address is explicitly computed and stored into a dedicated "Address register" (in Y32: A0 to A7), which triggers the TLB and cache checks, such that "a number of cycles later" the corresponding data is available in a coupled/associated "data" register (in Y32: D0 to D7). The #YASEP already uses this split scheme for 2 decades now.
And now, a similar decoupling scheme is also provided in the Y32.
So we get 8 visible registers : they must be saved and restored through all kinds of situations such as function calls, IPC or traps... yet there is no way to read them back to the general register file. The only way to get them out and back in is with the control stack, which can save 2 entries in one cycle.
So the pair T0-T1 can be saved and restored in one cycle, for example : it seems easier to pair them as neighbours. A whole set of targets can be saved in 4 instructions, 4 cycles. It still consumes a half-line of cache...
All the pairs of targets can be freely allocated by the compiler, with some hints and heuristics: the short-lived and immediate targets would be in the high numbers (T4-T7) while targets for later would be in the lower addresses (T0-T3). This makes it easier to save the context across the functions, as the buffer would be defragmented and there are fewer chances to save a register that doesn't need backup.
Another thing I didn't mention enough is that the control stack (its neighbour) also has hidden entries in the eBTB. Let's say 8 more lines (or even pairs for the double-buffering) which are allocated on a rolling basis. The stack manages the allocation and prefetch itself. Usually, these hidden lines are a copy of the current instruction buffer and its double/prefetch buffer, so there is only need of prefetch when the stack is emptying.
But the v2.0 goes beyond that: it manages the call/return and others, without the need for explicit saving/restoring by discrete instructions. These spill/unspill instructions are still possible but they take precious space (hence time).
What call and IPC now do is accept a 2-bit immediate (on top of the 3-bit target, the condition flags, the base address...) to say how many pairs of targets to push/pop automatically on the control stack.
But each pop or push takes a whole cycle, right ? Call already takes some time to push the PC and the context/base address.
The solution (which might sound familiar to Duane for example) is with a register window. In our case of 8 targets, 16 actual lines are actually implemented and addressed in a circular buffer. This means that a "base index" is added to the instruction's 3-bit Target ID to get the actual number of the physical entry.
What call/return do is simply add their 2-bit amount to the base index (shifted by 1) to make new entries available, while the old entries (now out of reach) can get saved in the background on the control stack, during the following cycles.
The granularity of 2 entries per cycle simplifies a few things, such as the computation of the effective index of the target/line, since the LSB is not changed. The instruction provides 3 bits but only 2 must be added to the current index, which is 3 bits as well but the LSB is implicit. That's a matter of a few XOR at most, so not a critical performance hog, unlike with a more classical register set in SPARC for example.
- Addressing a line from an instruction's target ID field is relatively simple: of the 3 bits, the LSB is preserved (pass-though) and the remaining 2 MSB (0-extended) are added to the 3-bit Target Based Index. Carry out is not calculated, it's a simple wrap-around.
- call instruction : 0-extended 2-bit field is added to the 3-bit TBI.
- ret only pops the destination, then also re-executes the call instruction to see how many levels must be restored, as well as which base register to restore.
Initially I was thinking that the 3-bit Target Based Index should be saved in the PC's MSB but it is not necessary if the stack is correctly emptied/spilled on the control stack. This TBI could be any value as long as the data is appropriate on the lines. It's all relative so who cares now ?
The control stack has a more straight-forward, direct addressing scheme, with 3 bits in the PC's MSB, next to the type field.
A typical function call would look like :
; main function: pf.t7 subfunction ; (a 24-bit immediate and 3 bits for TID) ; .. fill with some useful work if available ; while target #7 is being prefetched call t7, condition, a6, 2 ; t7 : target line 7 ; condition : the call can be "always" or check some flags ; a6 : the context/base pointer for the current function, to be saved. ; 2 : save 2 pairs of target lines, for reuse later. ; ... the rest of the function subfunction: ; ... do something ; all 8 of the target lines are available ; and can be overwritten/spilled/unspilled if needed. ret ; (eventual condition)
That's ... quite short, right ? Of course I didn't show the passing of parameters, which are moved/prepared in the sequence just after the prefetch instruction.
The function may choose to spill 0, 2, 4 or 6 targets across the call. During traps and/or IPC, it should be possible to also spill all the 8 current targets.
The depth of 16 entries is just enough to make the system work OK. 32 entries would use a lot more room for a smaller speedup.
The other very cool thing about this "target window" system : you can repeatedly call a function and the intermediate targets will remain in cache, in the window, speeding things up even more. There is a small stacked context, not just on the control stack but also the eBTB. This increases cache hit rates, frees some memory bandwidth in repetitive cases without programming efforts...
Second sketch
06/26/2024 at 14:49 • 0 commentsI have the drawing somewhere but it's not very different from the first one. There are two significant changes though.
The first change is the "instruction buffer", ex-Instruction L0, now called "explicit branch target buffer" (eBTB). It's a big change that also affects the instructions so I'll cover it later in detail.
The second change is the instruction decoder that is now meant to decode 3 instructions per cycle, instead of two. It uses an additional third slot in parallel with the 2 other pipelines (each inside one glob) to process the control stack, the jumps, the calls, the returns, and other instructions of the sort.
I couldn't... I just couldn't resolve myself to make a choice of which pipeline had to be sacrificed or modified to handle the jumps. And the nature of the operation is so different that it makes no sense to mix the control flow logic with the computations.
Ideally, the instructions are fed in this order : Glob1-Glob2-Stack. Any "slot" can be absent, so the realignment is going to be a bit tricky, and it increases the necessary bandwidth for the memories (FSB and caches). But the ILP can reach 3 in some cases, and is better than if I mixed the stack decoder with the Glob2 decoder, as this would create slot allocation contentions.
So the overall effect is a reasonable increase in ILP, the glob decoders remain simple, a special dedicated datapath can be carved out for the stack's operation and the "control" slot only communicates with the globs through status bits.
The other change, as alluded before, is with the instruction buffers that cache the L1, which are now explicitly addressed (at least at a first level). Most jumps work with a prefetch instruction that targets one of the lines, then a "switch" instruction that selects one of the lines for execution (and may stall if absent yet).
I have allocated 3 bits for the line ID. That makes 8 lines for prefetching upcoming instructions for a branch target. More lines (4?) are also dedicated-linked to the control stack.
Another line is the PC, which is actually implemented as a pair of line for double-buffering.
A direct Jump instruction acts as a direct prefetch to the double buffer, but it will stall the pipelines.
The targets for function calls, loops, switch/case, IF, and others are easy to statically schedule a few cycles in advance most of the time, leading to an efficient parallelism of all the units. Then a variety of branch instructions will conditionally select a different eBTB line ID, which gets virtually copied into Line #0.
So the eBTB has 2+8+4 lines working as L0 with specific ties to other units. More are possible using indexed/relative addressing of the eBTB.
This scheme mimics what is already happening with the data accesses : the core is decoupled from the memory system and communicates through registers. Instead, here, there is no register even though the lines virtually count as 8 address registers. But you can't read them back or alter them.
- A given target line can only be set with a prefetch instruction.
- A target line's address can be saved on the control stack (SPILL) and restored (UNSPILL), under program's control.
- Target lines are invalidated/hidden/forbidden across IPC/IPE/IPR because the change of the module makes the address irrelevant. However the addresses remain in cache and the stack keeps some extra metadata to keep the return smooth.
So the Y32 behaves as a 3-pipeline core, with one register set per pipeline, where the 2 short data pipelines (read-decode / ALU / writeback) can communicate with each other and memory, but the control/jump pipeline can't readback or move outside of its unit, to preserve safety/security/speed. The only way to steer execution of the control unit is:
- with explicit instructions containing immediate data,
- or by reading flags and status bits from the other pipelines.
The recent reduction of the PC width (now 24 bits) changes a lot of things compared to a classical/canonical RISC CPU and this enables certains instructions and combinations, while also reducing the computation's critical datapath.
Compared to YASEP32, the core is larger but has higher ILP and can reach higher operating frequencies due to finer pipelining, Y32 is also more capable of keeping a high throughput because it is designed to better handle cache memories from the ground up.
