• Another direction
    Jacob David C Cunningham05/15/2026 at 00:56 0 comments
    Recently I interfaced with these 8x8 ToF ranging grid sensors.
    Made me think I could try them out for a keyboard. I don't know maybe something obvious that would make it not work but could be cool to train an ML model.
    There would also be a companion app that shows the real-time depth sensing.
    These sensors have a 45 deg FOV so you'd need more than two... otherwise it'd have to be far away. Maybe 4. I did buy 5 so...
    The FOV on these sensors is not  big.... so like I said you would have to have more than 2. Doing some modeling in sketchup with 1 sensor it has to be at least 8" away to cover my hand. Two of them maybe cuts that in half.
  • Sad man needs a filter
    Jacob David C Cunningham06/04/2024 at 23:28 0 comments
  • Slow progress
    Jacob David C Cunningham06/04/2024 at 06:25 0 comments
    Most of my time right now is devoted to making money (low labor jobs) or trying to get a new job (in tech).
    I'm also a noob right now in ML/CV but I'm working on it.
    This video is about adding a status LED, doing an initial recording of data (IMU + pulling frames from a video with ffmpeg).
  • Going at it blind
    Jacob David C Cunningham05/28/2024 at 05:08 0 comments
    There's probably an obvious reason why this won't work (ex. camera vibrates every time you type).
    It is a fantasy of mine to be able to just tap on my legs and type (based on QWERTY layout). To track your fingers/hands, there are many approaches... usually though it's cumbersome (a lot of parts) or some magic is involved.
    This is not directly going towards that, it's a physical platform to work on. I know almost nothing about computer vision/ML but I have an idea of what I need to do to get this to work (combine vision and IMU data).
    You can see this sample image here the pinkies are almost not visible so not sure how that will go.
    This is using a Pi Zero 2 W and V3 wide camera module. Unfortunately this pi's wifi is messed up... so I'm using a USB WiFi dongle for development through SSH but eventually it'll just run on its own and use bluetooth hopefully to work as a keyboard (possibly trackpad too).
    Pretty ambitious project but I gotta get this vision stuff down.
