Hackaday.io Hackaday.io
Sign up Log in
FPGA Implementation of the Gigatron TTL Computer
The CPU-less Gigatron TTL computer running on a Tang Nano 9K FPGA board. If soldering sucks...
doctor-voltDoctor Volt
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 2
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
409
0
5
5
Team (1)
  • doctor-voltDoctor Volt
Join this project's team
  • Gigatron on FPGA
hardware
completed project
FPGA retro computer Gigatron TTL Compuuter
This project was created on 05/28/2024 and last updated 2 years ago.
Description
FPGA implementation of the Gigatron TTL microcomputer. The Gigatron is an 8-bit computer entirely made from classic 74-series logic ICs. The system can be connected to a VGA monitor, where it supports a resolution of 160 by 120 pixels at 64 colors. Furthermore, it features a four channel four bit audio synthesizer and is controlled by an NES-compatible game controller. Thus, the Gigatron functions as a full-blown 80s microcomputer that can be used to play video games. But instead of soldering all 38 chips and several diodes and resistors, I built one on a tiny piece of Silicon, an FPGA. The implementation was made for the Tang Nano 9K FPGA board. It includes an adapter board with voltage level converters that convert the 3.3 and 1.8V from the IO pins to the 5V TTL levels of the game controller and VGA monitor. It also includes the resistors for D/A conversion of sound and video as well as the connectors.
Details
Components
  • 1 × Tang Nano 9K FPGA Board
  • 1 × Custom made PCB
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Retro computer utilizing classic MOS6502 microprocessor.
Project Owner Contributor
6502 retro computer
marek-wicekMarek Więcek
Built to learn the iCE40 FPGA family, this devboard main purpose is to play with softcore processor designs
iCE40UPDevBoard - FPGA, VGA, RTC, PS/2
lawrence-manningLawrence Manning
NeoApple2 - A Port of Apple2fpga to Xilinx FPGA
Apple II Plus Emulation on PYNQ-Z1
feng-zhouFeng Zhou
A 65c02 based homebrew computer
Steckschwein
thomas-wThomas W.
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "FPGA Implementation of the Gigatron TTL Computer", please tell us the reason.
Send message
Remove Member
