Retroactive log 3: Hardware design and features
A project log for RetroMedleyCard
A retro emulation system on a <=2mm thick business card, using ideas borrowed from other projects and a sprinkling of insanity...
eontronicsEontronics • 05/30/2024 at 20:07•0 Comments
With an overarching plan established to set the direction of the design, it's time to actually produce a PCB layout and determine all the little ancillary components to support the main processors.
So, following a hectic bank holiday weekend stuck in front of KiCAD and countless datasheets, I eventually managed to cram everything onto this board:
To give a quick overview of the specs:
The board itself has a number of "interesting" design choices baked in to keep profile and cost to a minimum:
Putting all this together results in a board which should have no components taller than the 0.9mm-ish tall QFN packages, resulting in a total thickness of only 1.7mm!
With all the questionable features implemented, it's just a case of sprucing up the silkscreen and sending it off to be manufactured (no points for guessing where though!)
As it turns out, PCB art is hard, and not yet in my acquired skill set, so I instead resorted to using this cool font "AmazDooM" uploaded by Amazingmax. Thanks!
