The RP2350 Dilemma
A project log for RetroMedleyCard
A retro emulation system on a <=2mm thick business card, using ideas borrowed from other projects and a sprinkling of insanity...
eontronicsEontronics • 08/11/2024 at 01:24•0 Comments
New chip day (well a few days ago now)! And of all the chips it could be, there’s finally a successor to Raspberry Pi’s RP2040 microcontroller - the RP235x line.
While initial reactions appear mixed, with questions on whether the chip stands out from the competition (much like when the RP2040 was launched), I am firmly excited by the prospects the RP2350 offers - to the point I’m considering completely redesigning RetroMedleyCard around this chip…
So what makes this chip so enticing that I would throw away much of the design effort that’s gone into RetroMedleyCard so far? After briefly reading through the datasheet, I’m convinced the RP2350 could stand as a single-processor solution for RetroMedleyCard, rather than the mixed ESP32-S3 application processor + RP2040 video coprocessor currently implemented, thanks to several upgrades bestowed upon the RP2350 compared to its predecessor:
All of this is enticing as reducing RetroMedleyCard to a single processor-chip design will greatly simplify both hardware and software fronts. There will be no need to transfer frame data between processors, or to lay out multi-bit wide buses between chips, no need to store and upload code to the video adapter processor at runtime, no need to perform tight synchronisation between transferring pixel data and active region selection commands. Keeping all of this functionality contained in one chip, in one set of addressable memory, should just be easier.
That said, such a shift will still require a substantial amount of work. Aside from the fact the the PCB layout will essentially be reworked from scratch, I would also need to consider the difficulty of porting Retro-Go from the ESP-32 to the RP2350. At the very least, anything dependant on the ESP-32’s peripherals via the ESP-IDF will need to be rewritten for the chip. Additionally, the RP2350 requires PSRAM to be added to the QSPI bus, whereas the ESP32-S3 is available with internal PSRAM attached to an Octal SPI bus, potentially offering more memory bandwidth, which may end up bottlenecking emulator performance. There’s also a handful of minor issues that will need to be considered:
I could go on and on about what I think of this new chip, but that would quickly get off-topic from its applicability to RetroMedleyCard. A sensible next step would be to put an RP2350 development board on order and grab the latest version of the SDK to see just how much work porting Retro-Go to the chip will entail, I could then decide from there whether a total redesign around an RP2350 is a viable approach going forward.
