Code now available in GitHub
A project log for Linamp
Your favorite music player of the 90s, but in real life
rodmgRodmg 06/07/2024 at 02:500 Comments
The source code for the Player application is now public in GitHub: Linamp
If you want to try it, you should be able to run it on a modern Linux distribution, I've tested it on Debian Bookworm, you just need to install the Qt development packages, the dependencies mentioned in the repo's README and QtCreator from the official repos and you should be able to build and run it.
