A new version of linamp-player is now available! This update adds a full graphic equalizer on the player, applied system-wide through PipeWire so every source can share the same tone shaping.
What’s New:
- 10-Band Graphic Equalizer: Tune your sound with a multi-band EQ, implemented as a system-wide PipeWire filter-chain.
- Equalizer Presets: Use built-in presets or save, update, and delete your own custom curves.
- Equalizer UI: New equalizer screen with a live response graph, preamp and per-band faders, and an ON toggle so you can bypass EQ without losing your settings.
How to get it:
- Build your own setup: Download the latest
.debpackages for your platform from the GitHub releases page (v1.6.0). - Ready-to-run on Raspberry Pi 4: If you’d rather skip assembling the stack yourself, store.linamp.org offers a Linamp OS SD card image with linamp-player v1.6.0 preinstalled. You can buy that image on its own, or as part of the full DIY Digital Pack (guides, fabrication assets, and the OS image together)
Pack and OS downloads are now labeled v1.6.0-r1: 1.6.0 is the player version in the image, and -r1 is the pack revision when guides or the OS image change without a new player release.
If you already own Linamp OS or the DIY Pack, check your purchase email for the updated download link.
Thanks for following the project!
Rodmg
