linamp-player v1.5.0 released - Debian 13 support and CD gapless playback
06/22/2026 at 14:41 • 0 commentsA new version of linamp-player is now available for download! This update focuses on playback performance, stability, and adding gapless playback to the CD player.
What’s New:
- Gapless CD Playback: Enjoy seamless transitions between tracks when using the CD player source.
- Enhanced Stability: I've rewritten the CD player source in native C++ and refactored the File source for a smoother, more reliable experience.
- Modernized Codebse: Refactored parts of the code to be more future proof and compatible with the latest Debian release.
You can get the latest binaries from GitHub.
If you are using Linamp OS, you should have gotten an email with the link to download the latest version that includes linamp-player v1.5.0.
Otherwise, if you'd like to get Linamp OS or build your own Linamp player and support the project, you can get it here: https://store.linamp.org/
Thanks for following the project!
Linamp Demo - March 2025
03/18/2025 at 05:27 • 0 commentsFeatures demo of Linamp, your favorite music player of the 90s, but in real life, as of March 2025.
Build your own Linamp player and support the project: https://store.linamp.org/
linamp-player v1.4.0 released - Spotify source and UI improvements
12/30/2024 at 21:47 • 3 comments![]()
A new version of linamp-player has been released, it includes two big features I really wanted to finish:
1. UI Improvements:
- The volume and balance sliders now change color depending on their values, just like the original Winamp skin did:
- Redesigned the Sources menu, it is no longer a placeholder!
2. Spotify Source:
Linamp can now be used as a Spotify Connect speaker thanks to librespot! From the Spotify app in your smartphone, Linamp will appear as a playback device, selecting it will transfer playback from your phone to Linamp.
It supports showing the song metadata, progress and spectrum analyzer.
At this point it doesn't support controlling playback from Linamp.
Please note that in order for this to work you need to install librespot and customize several configurations, this is partially done on the Linamp OS included with my Linamp DIY Digital Pack, see the next section on detail on how to set it up.
How to upgrade
If you have the latest Linamp OS from my Linamp DIY Digital Pack, you can upgrade by connecting via SSH and running the following commands:
sudo apt-get update sudo apt-get install --only-upgrade linampYou will also need to update the librespot service configuration, you can do it with this script:
sudo bash -c "cat <<'EOF' > /etc/systemd/user/librespot.service [Unit] Description=Spotify connect client After=wireplumber.service StartLimitIntervalSec=0 [Service] Type=simple StandardOutput=journal ExecStart=/usr/bin/librespot --disable-audio-cache --quiet --name Linamp --device-type speaker --bitrate 320 --backend pulseaudio --onevent=/usr/lib/python3/dist-packages/linamp/spotifyplayer/librespot-event-handler.sh Restart=always RestartSec=5 Slice=session.slice [Install] WantedBy=default.target EOF"Then, just restart the device:
sudo rebootI you are not using Linamp OS, you can get the latest binaries here: https://github.com/Rodmg/linamp/releases/tag/v1.4.0
Please note: If you are not using Linamp OS, you will need to install librespot and configure it to run as the same user you use to run linamp-player, configure it to use pulseaudio and point the events script to /usr/lib/python3/dist-packages/linamp/spotifyplayer/librespot-event-handler.sh, how to do it will depend on how your OS is setup.
linamp-player v1.3.0 released - Bluetooth Source
12/21/2024 at 03:22 • 1 comment![]()
Hi! I've finally got the time to finish the Bluetooth Source! now Linamp can be used as a Bluetooth audio receiver.
It automatically detects when a smartphone or other device connects and shows the media metadata, playback state and the spectrum analyzer. It also allows you to control playback via the buttons on the Linamp interface.
If you have the latest Linamp OS from my Linamp DIY Digital Pack, you can upgrade by connecting via SSH and running the following commands:sudo apt-get update sudo apt-get install --only-upgrade linamp sudo reboot
Otherwise, you can get the latest binaries here: https://github.com/Rodmg/linamp/releases/tag/v1.3.0
Please note: If you are not using Linamp OS, you will need to install bluez and configure it to accept connections and work as a Bluetooth audio receiver. -
Linamp DIY Digital Pack now available!
09/11/2024 at 02:16 • 2 commentsI've just released the Linamp DIY Digital Pack, It includes everything you need to fabricate and assemble Linamp, with detailed written and video tutorials, tips on how and where to purchase parts, digital files for 3D printed and sheet metal parts, and a full pre-configured SD card image for the Raspberry Pi.
Get yours here!: https://store.linamp.org/
The Pack includes:
- Guides - Video tutorials and written guides on:
- Available options for the player case (Sheet metal vs fully 3D printed)
- Ordering the sheet metal case
- 3D printing the case
- 3D printing the player face
- Sourcing parts with full Bill of materials
- Preparing the power button and screen
- Assembly
- Flashing the SD card and initial setup
- Advanced configurations and troubleshooting
- Fabrication assets - the files needed to fabricate sheet metal and 3D printed parts
- Software - The OS for Linamp in a SD card image
If you build one, I would love to see it! let's make Linamp the best hackable music player out there!
Debuging Screen issues
06/20/2024 at 23:13 • 0 commentsRecently I started building a second Linamp, using some extra spare parts I had from the original build and ordered the rest of the parts I needed.
One of the most important parts is the screen, it is sold under several brand names by different sellers in Amazon and originates from China, the generic model seems to be "P79-T", which is a 7.9'' ultra wide screen with touch capabilities.
When I did the original build, I struggled to get it working correctly with the Raspberry Pi - because it uses a non-standard resolution, it requires some manual configuration in order to make it work, which is specified in the manual that comes with the screen.
The thing is, the configuration values mentioned in the manual don't really work, and now I just discovered that the correct settings seem to vary between same-model screens.
In short, the configuration needed involves modifying the "config.txt" file that lives in the Raspberry Pi boot partition, the manual instructs you to set the following values:
# DON'T USE THIS! This probably won't work max_usb_current=1 hdmi_group=2 hdmi_mode=87 hdmi_timings=400 0 100 10 140 1280 10 20 20 2 0 0 0 60 0 43000000 3However, when I used those values on my original screen, I got a flickering image with glitches and lines:
After a lot of trial and error, I was able to fix it by using the following values:
# config.txt changes that worked for my original screen hdmi_cvt=400 1280 60 3 hdmi_group=2 hdmi_mode=87 hdmi_drive=2 dtoverlay=vc4-kms-v3dI also updated the cmdline.txt file, which controls the startup of the Linux Kernel, adding the following parameters:
video=HDMI-A-1:400x1280M@60,rotate=270
This worked! I now got a clean picture and everything seemed to work great!
However this was not the whole story...
Now that I'm building a second device, I used another sceen, which came from the same Amazon vendor, in the same box, same manual and same outside looks, but when I connected it to the Raspberry Pi with the same SD card as before, I got a different set of glitches:
These screens come with a metal shell which I remove in order to fit it inside my custom case, when I opened it, I saw a slight difference:
My original screen back side:
The new screen back side:
As you can see, the electronics seem the same, but the actual display panel is different.
And now I also know that the hdmi timing configurations for these are also different.
Understanding the issue
There are several things at play here. First of all, these screens, when connected to a macOS or Windows PC, work just fine, but when connected to a Linux machine, being it a Raspberry Pi or PC, they have the issues I'm seeing.
This seems to be due to non-standard HDMI protocol implementations in these screens, which macOS and Windows seem to correctly parse (probably because when these screens were designed, they were tested to work on those OSes primarily), but Linux is having issues with it.
Specifically the issues seem related to the "EDID" a kind of identification that displays send to the host computer when connected, which tell the computer what video modes the display supports so it can auto-configure it.
So that's why the manual instructs us to use the "hdmi_timings" in the Raspberry Pi - that setting overrides the auto configuration of the display and forces specific signal timings that the display needs to work.
Those timings seem to depend on the actual display panel, so they seem to vary. In an ideal world, the controler board on the display would be correctly configured to report the actual good values the panel supports to the OS, so the OS could auto configure it. But the world is not ideal.
Also, now comes another complication: How did I manage to make it work without using hdmi_timings on my original display? Well, it turns out that I didn't get it 100% right there, if you look closely, when the Raspberry Pi boots, it firsts displays a test color pattern, and then starts showing some text while the Linux Kernel boots, then, the screen flickers, and you get more Linux kernel text, then it flickers again and you get your graphical interface.
So, if you look at those details when Linamp boots, you will see that we still get the glitches on the first screens, and those only get fixed once we get into the Linux kernel and the graphical interface. (I disabled the actual test pattern and kernel output so you cannot see it easily).
I'm using DietPi Bookworm, which is a recent release with a recent Raspberry Pi Linux kernel, this means that we are now using the new open-source KMS graphic driver. Previously, the Raspberry Pi used a propietary graphics driver which delegated a lot of the display interfacing to the VideoCore GPU, including the screen timing configurations. Now, the KMS driver does this, so we have two different codebases interfacing with our screen: During the initial test pattern and kernel loading screens, we are on the boot loader which is still using the VideoCore GPU directly to configure the screen, here is where the hdmi_timings and any other setting in the config.txt file is being used. However, due to the dtoverlay=vc4-kms-v3d setting I used, when we get into the Kernel, we start using the KMS graphic driver, which seems to correctly detect my original screen and configures it correctly. However this is not the case with the second screen.
Figuring out the timings for the second screen
First I did some more trial and error, with no success, and then I did some reading.
These resources got me to the right path:
- Using Weird Displays with Raspberry Pi: https://learn.adafruit.com/using-weird-displays-with-raspberry-pi/everything-else
- Raspberry Pi config.txt docs: https://github.com/tback/raspberrypi_documentation/blob/master/configuration/config-txt/video.md
- Troubleshooting KMS HDMI output: https://pip.raspberrypi.com/categories/685-whitepapers-app-notes/documents/RP-004341-WP/Troubleshooting-KMS-HDMI-output.pdfThe last one was specially clarifying, it explains the change from using the propietary graphics driver to the KMS driver and the differencies and issues that could arise, also the Adafruit post helped me on how to derive the timing values, altough some of the steps there don't apply anymore due to recent changes in software.
The solution so far has been to not use KMS and force using the propietary driver, and also derive a specific set of timing values for the device.
These are the steps I followed to derive the hdmi_timings:
- In config.txt, enable KMS by setting `dtoverlay=vc4-kms-v3d` and reboot
- SSH into the pi and, with the screen connected, do `edid-decode /sys/class/drm/card1-HDMI-A-1/edid`, you will get something like this:
Detailed Timing Descriptors: DTD 1: 400x1280 59.995729 Hz 5:16 82.194 kHz 61.810000 MHz (side by side interleaved, 296 mm x 1280 mm) Hfront 160 Hsync 32 Hback 160 Hpol P Vfront 30 Vsync 30 Vback 30 Vpol N- Follow https://learn.adafruit.com/using-weird-displays-with-raspberry-pi/everything-else#hdmi-timings-if-necessary-3080203 to derive the values, start with this: `hdmi_timings=400 0 100 10 140 1280 10 20 20 2 0 0 0 60 0 43000000 3` and update all the values except aspect_ratio and the ones that are not specified in the guide.
- Update config.txt with the new hdmi_timings and comment out `#dtoverlay=vc4-kms-v3d`. Reboot.
After all this, my changes to config.txt looked like this (showing only relevant lines):
hdmi_group=2 hdmi_mode=87 hdmi_timings=400 0 160 32 160 1280 10 30 30 30 0 0 0 60 0 61810000 3 hdmi_drive=1 hdmi_force_mode=1 display_hdmi_rotate=1 #dtoverlay=vc4-kms-v3dAnd now, the new display works perfectly! Even the initial bootloader screens look perfect.
However, If I connect the original screen, it again has glitches, I'll probably need to derive a different set of hdmi_timings for that one.
Update: Here are the correct timings for my original screen, derived following the previous process:
hdmi_group=2 hdmi_mode=87 hdmi_timings=400 0 50 30 50 1280 10 30 20 30 0 0 0 60 0 43240000 3 hdmi_drive=1 hdmi_force_mode=1 display_hdmi_rotate=1 #dtoverlay=vc4-kms-v3dThe Dilema
Now the dilema: I wanted to distribute updates to Linamp as OS images, however with this new finding, so far I cannot guarantee that my updates will work with all screens.
I've ordered a third screen to see if I get the same issue again or if I can see any kind of pattern, to get a better solution. Otherwise we will need to keep our hdmi_timings for each device and remember to update those if we reflash the SD card.
Thank you! - Figuring out logistics
06/18/2024 at 23:50 • 0 commentsLinamp started as a personal DIY project, something I did for myself and just showed to a couple of friends. Thanks to one of those friends, Javier, who insisted on me publishing it, I got the courage and wrote this project page.
Since its publication, I've seen an amazing response from people around the world, this really gives me motivation to continue improving this project and sharing it with the world. For all that, Thank you!
I've been seeing a lot of interest from people who want to be able to purchase the player, so I'm trying to figure out the logistics to make this a reality.
Getting there is no small step for me, so I would like to request the help of the community by filling this survey: https://forms.gle/nvo1WEPQZNkJo2Yp6
Your response will greatly help me to plan the next steps for this project.
Please note: Linamp is and will continue being an Open Source project, this effort aims to make it available to more people and start a community around it, I'm excited to see what you will do with it! -
Video: Linamp UI demo
06/07/2024 at 04:06 • 0 commentsI've uploaded a video showing the main features of the Linamp UI, you can watch it here:
Code now available in GitHub
06/07/2024 at 02:50 • 0 commentsThe source code for the Player application is now public in GitHub: Linamp
If you want to try it, you should be able to run it on a modern Linux distribution, I've tested it on Debian Bookworm, you just need to install the Qt development packages, the dependencies mentioned in the repo's README and QtCreator from the official repos and you should be able to build and run it.
Rodmg
