Success* at last
A project log for Barnabas-Bot
An open-source educational robotics project that inspires elementary and middle school kids to invent through building their own robot
ericeric 12/02/2017 at 18:050 Comments
 I got the board working;
For the most part at least. The board gets power, can communicate via usb, accept code, and power components such as motors. However there is still a problem. That being the board's inability to receive power from USB. I think that the reason for that is a fundamental misunderstanding of p-mosfets.
    I am well aware that p-fets act as inverters, only turning the channel on if the gate is low. However when routing the board I forgot that current only flows from source to drain in a p-fet. Thus the power management subsystem that allows the board to receive power via USB is essentially backwards.
    So I need to Mcgyver the board in a way that allows me to verify this. You will probably be hearing from me again soon.
Till next time,
-Eric
