Initially I tested the Melexis 90614
sensor (I chose this sensor due to it's smaller field of view
compared to other sensors I looked at). While the sensor worked
perfectly, it was only good for short range (under 10cm) – I
expected this might be the case which is why I detailed the method of
narrowing the field of view in my last post. I tried that method by
using a 1mm hole (in polished steel sheet metal) and placing it 1mm
from sensor. Well, no luck. This only resulted in cutting the total
IR getting to sensor (limited view by cutting everything else out –
not by focusing field of view to smaller area, which would utilize
the whole sensor).
This led me to dropping the whole idea
of measuring changes in temperature of the “cheek” area due to
not being able to focus a sensor on a small area from any reasonable
distance. Well, that is, until I met Michael Shaub at the Hackaday Un-Conference in Chicago. Talking to him about his IR Imaging
project DIY Thermal Camera , as well as his presentation of the
project, gave me the motivation to look further into how these
sensors can be focused on a small area at a greater distance from the
sensor.
Presently testing out ideas using: Infrared Laser Thermometer Pittsburgh® - Harbour Freight item#93984 ($18.99) (which I think is the one Micheal is using). Basic specs for this are below:
- 6:1 spot size to distance ratio
- Non-contact IR thermometer pin-out
- Data (pin D on module) to pin 12
- Clock (pin C on module) to pin 2
- Power (pin V on module) to diode from 3.3V supply
- Ground (pin G on module) to ground
Test results coming soon!
Tom Meehan
