Imagine Dragons' Radioactive
By HexHammer
Record the audio
- Record 'radioactive' on guitar in one take, save it using arecord. It's best to use AAC format for this, MP4 seems to prefer it :
$ cd Desktop
$ mkdir radioactive
$ cd radioactive
$ arecord -f S16_LE -r 44100 -c 2 -V stereo radioactive.aac --> cd quality, 2 channels, stereo vumeter.Film the video
- Film each hand separately using Kazam to capture AIMos while 'playing' along to the AAC.
- Film my face singing along to the recording the same way, using the capture audio option to record the speakers, not the mic. The audio is to be used as a cue marker later :
$ kazam &
$ cd ../aimos/motion
$ ./motion.sh- Using nano, write out the lyrics into a file (each piece on a new line, optionally followed by a comma and the colour.
$ cd ../radioactive
$ nano radioactivelyrics.txt
I'm waking up,white
to ash and dust
I wipe my brow
and I sweat my rust
I'm breathing in
the chemicals
I'm breaking in
shaping up
then checking out
on the prison bus
This is it
the apocalypse
Whoa-oh
I'm waking up,yellow
I feel it
in my bones
Enough to make
my systems blow
Welcome to the new age...- While playing back the recording, use Kazam to capture the Python window while using the spacebar to step through the lyrics file. Use the capture audio option again :
$ kazam &
$ python pygamelyrics.py>> import pygame
>> from pygame.locals import *
>> pygame.init()
>> pygame.font.init()
>> legend=pygame.font.SysFont('Sans', 72,bold=True)
>> w=1024; h=768
>> window = pygame.display.set_mode((w,h))
>> pygame.display.set_caption(str(w)+","+str(h))
>> screen = pygame.display.get_surface()
>> lfile=open('radioactivelyrics.txt','r')
>> lyrics=list(lfile)
>> lfile.close()
>> print 'ready? click on the display and press space.'
>> waiting=True
>> while waiting:
>> events = pygame.event.get()
>> for event in events:
>> if event.type == KEYDOWN:
>> if event.key == K_SPACE: waiting=False
>> print 'running...'
>> cr=255; cg=255; cb=255
>> for l in lyrics:
>> waiting=True
>> if ',' in l: # current text colour can be specified after a comma
>> col=l.split(',')[1].strip() # in the radioactivelyrics.txt file
>> if col=='white': cr=255; cg=255; cb=255
>> if col=='red': cr=255;cg=0;cb=0
>> if col=='yellow': cr=255;cg=255;cb=192
>> if col=='green': cr=0;cg=255;cb=0
>> print l.split(',')[0]+'<'+col+'>'
>> r=cr; g=cg; b=cb
>> while waiting:
>> events=pygame.event.get()
>> if event.type==KEYDOWN:
>> if event.key==K_SPACE: waiting=False
>> pygame.draw.rect(screen,(0,0,0),(0,0,w,h))
>> txt=l.split(',')[0].strip().lower()
>> text=legend.render(txt, True, (r,g,b))
>> tw=text.get_width()
>> th=text.get_height()
>> screen.blit(text,((w/2)-(tw/2),(h/2)-(th/2)))
>> pygame.display.flip()
>> r=r-1; g=g-1; b=b-1
>> if r<0: r=0
>> if g<0: g=0
>> if b<0: b=0
>> print '\ndone'
>> sleep(5)
>> pygame.display.quit()Edit the video
- Make a folder for each channel, then use avconv to split the mp4 files up into frames in the channel folders. If you dont have avconv you can replace it with ffmpeg, they are completely interoperable :
$ mkdir face
$ mkdir left
$ mkdir right
$ mkdir lyrics
$ avconv -i face.mp4 -f image2 face/%04d.png or use ffmpeg -i face.mp4 -f image2 face/%04d.png
$ avconv -i left.mp4 -f image2 left/%04d.png
$ avconv -i right.mp4 -f image2 right/%04d.png
$ avconv -i lyrics.mp4 -f image2 lyrics/%04d.png
- Use mplayer to determine the start point of the audio in each mp4 in seconds, multiply by fps (15).
- Delete the leading frames from each folder and rename the images starting with 0000.png. Now all the frames are lined up on the original AAC audio across the 4 folders :
$ mplayer left.mp4 --> get frame number of start of audio.
$ cd left
$ ls >files
$ python ../r_delete.py
>> import os
>> fil=open('files',r)
>> lst=list(fil)
>> for f in fil:
>> os.remove(line.strip())$ rm files
$ ls >files
$ python ../r_rename.py>> import os
>> n=0
>> for f in list(open('files','r')):
>> nam='0000'+str(n)
>> if '.' in f: os.rename(f.strip(),nam[len(nam)-...
Victor Frost
Mark Dammer MM0DQM
Jacques Gagnon
Hi Mark, thanks! :-)
I didn't make it to post originally, it was supposed to be something to fill an evening... But I spent that finding out that my system doesn't get on with H.264 codec. By the time I'd found out what was crashing the transcoders, I realised I could just make
the video by hand. So I did...
So much useful stuff buried under a modern desktop I decided to share, I hope someone finds it useful as well as entertaining.
I wish I'd known how rare before I joined up, but that's kind of you to say. I'm notorious around here for it. I've had so many beatings, been gouged or ridden so many times that when the government tried to crush me I just gave up. I stopped painting, I cut my nails off and didnt touch any of my instruments, I stored my tools away. Cut my dreads and tried to pretend I was just average so they'd leave me and Bea alone.
That didnt work, so when I felt strong enough I made this profile to share it with the world at large...HaD has practically saved my life, Ive never been treated so well in all my years. (1.4k views on that ratty antenna lol, how did that happen?)
Hope things are good for you too. Crazy planet eh? :-)
