Hackaday.io Hackaday.io
Sign up Log in
CapiBridge LoRa and ESP-NOW Gateway for Home Assis
CapiBridge is an open-source gateway for low-power devices.
dmDM
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
420
1
4
2
Team (1)
  • dmDM
Join this project's team
  • GitHub
  • YouTube
completed project
hardware
home assistant GATEWAY mqtt ESP-Now
This project was created on 06/07/2024 and last updated 2 years ago.
Description
CapiBridge is an open-source gateway for low-power devices. It supports various communication technologies including LoRa, ESP-NOW, and WiFi. The gateway receives JSON strings from LoRa and ESP-NOW devices and publishes them to an MQTT server. It automatically separates the JSON string into dynamic MQTT topics based on keys within the JSON, such as "b" for battery or "m" for motion, making it highly compatible with Home Assistant. This gateway simplifies adding new DIY nodes/sensors to your smart home by standardizing the communication protocol across all projects, focusing on simplicity and unified protocol handling.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
DM wrote 06/07/2024 at 15:53 • point
I hope you enjoy this project.
The Hornet Nest Alarm Panel is a PoE-enabled security panel integrating wired systems with Home Assistant and ESPHome, offering 42 zones.
Project Owner Contributor
christopher-greenleeChristopher Greenlee
Distributed Volunteer Computing with IOT
GRIDSHELL
invpeinvpe
No more missed doorbell rings
ESPBell-MAX and LITE Intercom / Doorbell IoT modul
dmDM
IoTextra Octal3 brings latching I/O to IoTflow and IoThome so your relays stay exactly where you left them, even after a power cut.
Octal3: No Power. It Still Holds.
arshia-keshvariArshia Keshvari
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "CapiBridge LoRa and ESP-NOW Gateway for Home Assis", please tell us the reason.
Send message
Remove Member
