ATX-Pi
An unholy marriage of an Arduino, an ATX power supply and a Raspberry Pi.
The ATX-Pi was born out of the need to control an ATX power supply while simultaneously powering the Raspberry Pi from the power supply. The ATX-Pi adds "ACPI" type functionality to the Pi (automatic hardware based shutdown).
On the board is an Arduino clone powered on the 5V Standby rail. All unused digital/analog and serial pins are broken out, as well as the unused pins on the Pi ribbon cable. Also broken out are the main PSU voltages via the screw terminals you see next to the ATX connector. Any standard case switch set will work with this board so it will easily integrate your Pi project into a PC case. The hard drive and power LEDs will also plug into the board to give you indication on your case of the Pi's status.
My personal need arose when I became involved with ASIC Bitcoin mining. I needed a convenient way to safely shut off my Pi and my Power Supply, and for it to automatically resume operation once power is restored in case of Mains failure.
Demo/introductory video available at:
https://www.youtube.com/watch?v=DMrWX3kyayo
  • Installing the script on your Raspberry Pi
    kd8ssf07/19/2014 at 17:15 0 comments
    There are many flavors of Linux available for the Raspberry Pi, so I will focus on the generic Raspbian build as well as one for Arch Linux. Why Arch? I am using MinePeon in my Bitcoin mining rig!
    Raspian:
    First, install git if you haven't already:
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get install git-core
    Download wiringPi and install it:
    git clone git://git.drogon.net/wiringPi
    cd wiringPi
    ./build
    Create the shutdowncheck script:
    cd ~
    sudo nano shutdowncheck
    Type the following into the nano text editor:
    #!/bin/bash
    PATH=/usr/bin:/home/pi/wiringPi/gpio
    echo "Shutdown script starting..."
    echo "Asserting pins (7=in, low(pull-down); 8=out,high)"
    gpio -g mode 7 in
    gpio -g mode 7 down
    gpio -g write 7 0
    gpio -g mode 8 out
    gpio -g write 8 1
    COUNTER=0
    while [ 1 ]; do
    if [ "$(/home/pi/wiringPi/gpio/gpio -g read 7)" = "1" ]; then
    echo "PIN7 requested a SYSTEM HALT!"
    sudo halt -p
    break
    fi
    sudo sleep 0.5
    done
    exit 0
    After you have typed this in and double checked your work, press ctrl-o (to save) and ctrl-x (to exit).
    Next, make the script executable:
    sudo chmod 755 shutdowncheck
    Why type? Why can't I just pull it from your github? Because you can learn a bit about how gpio works on your pi by typing it manually. Also, some distros interpret new lines differently and you may end up with a non functioning script.
    Edit your /etc/rc.local file and add the following line before the last line (exit 0):
    sudo nano /etc/rc.local
    Add this line before exit 0:
    (cd /home/pi && exec ./shutdowncheck) &
    Save (ctrl-o) and exit nano (ctrl-x). Now your script will run automatically when your Pi starts up!
    Arch Linux (MinePeon specific instructions)
    Special thanks to synapseattack from bitcointalk.org for the MinePeon instructions!
    cd wiringPi
    ./build
    sudo cp /home/minepeon/wiringPi/gpio/gpio /usr/bin/
    sudo nano /usr/bin/shutdowncheck
    Type the following into nano and then hit ctrl-o (save) and then ctrl-x (exit):
    #!/bin/bash
    PATH=/usr/bin
    gpio -g mode 7 in
    gpio -g mode 7 down
    gpio -g write 7 0
    gpio -g mode 8 out
    gpio -g write 8 1
    COUNTER=0
    while [ 1 ]; do
    if [ "$(/usr/bin/gpio -g read 7)" = "1" ]; then
    sudo halt -p
    break
    fi
    sudo sleep 0.5
    done
    exit 0
    Make the new file executable:
    sudo chmod +x /usr/bin/shutdowncheck
    Now make it a service:
    sudo nano /usr/lib/systemd/system/shutdowncheck.service
    Type this into nano (ctrl-o and ctrl-x to save and exit):
    [Unit]
    Description=ShutdownCheck
    ConditionFileIsExecutable=/usr/bin/shutdowncheck
    [Service]
    Type=forking
    ExecStart=/usr/bin/shutdowncheck
    TimeoutSec=0
    StandardOutput=tty
    RemainAfterExit=yes
    SysVStartPriority=99
    [Install]
    WantedBy=multi-user.target
    Now enable your new service:
    sudo systemctl enable shutdowncheck.service
    Now your script will run during boot (you will need to reboot after enabling the service).
View project log
  • 1
    Step 1
    To assemble your ATX-Pi you will need the following tools: soldering iron, right angle wire cutters, and a roll of solder. Optional, but encouraged: a PanaVise Jr. or set of "helping hands" soldering clips.
    Step one: Place the 330 Ohm resistors on R1-R5 and solder in place. Bending one of the pins on the resistor helps hold it in place.
  • 2
    Step 2
    Step two: Place the R6 (1k ohm), R7 (10k ohm), the 16 MHz crystal (XTAL) and the 22 pF capacitors (C1/C2). Solder in place.
  • 3
    Step 3
    Step three: place the USB-A port on the board and solder in place, starting with the pins on the underside of the board. Next solder the 4 pins on the top.
View all 11 instructions
cfd-pipeman wrote 01/14/2015 at 02:51 point
OK, thanks for the information. I really appreciate you getting back to me.
kd8ssf wrote 01/14/2015 at 03:17 point
No problem, let me know if you have any other questions.
cfd-pipeman wrote 01/02/2015 at 02:52 point
I'm interested in this project because I have a RPi hooked up to two external hard drives. I want to power all three using an ATX PSU. Is that possible?
kd8ssf wrote 01/07/2015 at 23:09 point
Hello pipeman. That should be possible but it really depends on how the hard drives are powered. Can you supply more details about the hard drives or your current setup?
cfd-pipeman wrote 01/11/2015 at 21:21 point
I'm sorry I didn't see your response before now. I'm using two WD 3TB Red series hard drives. They currently are hooked to the RPI using two "SATA to USB" adapters. The whole setup is shoved into a mini ITX case. That's what gave me the Idea of using an ATX power supply to provide power to the RPi, and the hard drives, from one source instead of 3 different sources, like it is now. Let me know if you need more information.
kd8ssf wrote 01/13/2015 at 22:50 point
Am I correct in assuming that the USB adapters have separate power supplies? What sort of connectors are involved here? Do they use separate connectors for power and data on the hard drive end? If so you could just hook up SATA power connectors straight from the power supply. If the adapters themselves need to be powered you may have to break out the soldering iron and adapt a Molex connector, but as long as the adapters work at 5V that shouldn't be an issue either.
cfd-pipeman wrote 01/14/2015 at 01:37 point
Yes, the USB adapters have separate power supplies. each power supply has a molex connector that connects to an adapter that connects directly to the SATA drive. You can see what I mean in this picture: http://goo.gl/FzB32W I think you answered my question with your last post. I just didn't know, with your device, if the ATX PSU would still operate as it normally would and power the drives too. Do you still offer the ATX-Pi kit? I would be interested in purchasing one.
kd8ssf wrote 01/14/2015 at 02:31 point
I used to have one of those adapters myself actually, it was quite handy. You should be fine hooking up SATA power connectors directly from the PSU, as long as the adapter will draw it's own power from the USB connection to the Pi (I never used it in this configuration). I would NOT recommend using the included power adapter at the same time you have the PSU hooked up to the drives.
For me, an important design decision was to not require modification to the power supply. You will need an ATX 2.0 compliant PSU, and it should operate normally. Honestly, you could achieve the same effect by shorting the green wire (PS_ON) to ground while you want to have the PSU running. I designed this board to be a bit more elegant than a paper clip though, with a solid connection to the 24-pin ATX plug and a standard USB connection to deliver 5V to the Pi.
Unfortunately I sold out of my kits on my Tindie page and decided to "retire" the product there since they weren't exactly flying off the shelf (admittedly it is a very niche product). Please check my GitHub at https://github.com/KD8SSF/ATX-Pi . I have all the necessary "Gerber" files for board production with either OshPark (recommended) or SeeedStudio (a bit slower to receive the board but could be cheaper). There is also a full parts list and the Arduino code located there if you want to put one together for yourself. Good luck!
