the 611 is usually a 6+n wire intercom working analogue and pretty straight:
2 wires connect the opener at the door to the button in the intercom and the button shortens the wire on pressing. two other wires are connected to the bell.
however, with the ZER 622, this system is changed to become a 1+n wire system working with different voltage levels to indicate functions. So the bell is no longer two separate wires. it is indicated by a rise in the power level from 16 to 24 Volt.
luckily, the opener still works by shortening the 2 wires. :-)
I assume the central module recognises this short circuit to trigger the opener relais at the door.
so it is easy to use the Shelly plus UNI relais to create such a short circuit.
Christoph Winkler
bryan.lowder
Doubleyou
Fernando Zablah
