1Preparation
- Find your old game controllers
- Take off the battery clip on the back
2Disassembly
- Unscrew the 4 screws holding the case together
- Pry the top of the shell apart from the bottom of the shell (be careful of the 2 clips on the top of the controller by the power button as they are quite fragile and easy to snap off)
- Remove the old PCB from the game controller making sure to keep track of all the buttons and the membranes
3Assembly
- Place your OpenMote PCB into the bottom shell, make sure that the reset button slots in nicely to the hole in the bottom of the shell
- Place the top of the shell with the membranes and buttons onto the bottom and snap it all together
- Tighten the 4 screws to close up the controller
4Explore!
Your OpenMote is fully ready for your projects and creations! Share what you're working on with OpenMote and what kind of fun and exciting projects you're able to control.
