Accessing the R-Pi camera sensor
A project log for Basic lensless imaging for low-cost microscopy
My attempt to build a microscope without the most expensive part.
kyle-m-douglassKyle M. Douglass 08/26/2017 at 21:410 Comments
To prototype sample mounting and imaging, I need to have very close access to the Raspberry Pi camera sensor. This involved a bit of custom modifications, as I explain in my latest blog post:
http://kmdouglass.github.io/posts/accessing-the-raspberry-pi-camera-image-sensor.html
I have also finished the laser diode driver circuit with ON/OFF switching controlled by the Pi; I only need a few cables to test it. Once I do, I will post the final design of the driver circuit.
