Why
I was googling for a while how to do programming of this variant, and this setup seems to work. I used Platformio for the first time and it was really good experience. Zero hassle, and it just worked. On top of that, i got to use my preferred editor rather than the Arduino IDE.
Requred hardware setup:
  1. ESP-12E (mine says AI-Thinker)
  2. USB-serial adapter (mine is SILABS 2102)
  3. Breadboard and some wires
  4. Power supply of 3.3V (mine was shipped with the breadboard)
Image 1: Schema of the wiring. I used jump wires and it worked out just fine.
Required software setup:
I have ubuntu 16.04 running, but probably other similar distributions work fine as well.
  1. Install python-pip python-virtualenv cutecom
  2. Create new virtuaenv and install platformio inside it
    1. virtualenv ./ENV
    2. source ./ENV/bin/activate
    3. pip install platformio
Now the enviroment is set up, continue to creating the project and compiling:
  1. Create folder for the project and initialize it:
    1. platformio init --board esp12e
  2. Create sourcefile "src/main.cpp" with content below and compile
    1. platformio run
* Test ESP8266 wifi and programming. Will print wifi networks to serial and blink led on pin 13.
#include "Arduino.h"
#include "ESP8266WiFi.h"
#ifndef LED_BUILTIN
#define LED_BUILTIN 13
#endif
void setup()
  // initialize LED digital pin as an output.
  pinMode(LED_BUILTIN, OUTPUT);
  Serial.begin(115200);
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
void do_blinking()
  // turn the LED on (HIGH is the voltage level)
  bool state = 0;
  static const int LOCAL_DELAYS[] = { 200,400,200, 1000 };
  for ( int dloop = 0; dloop < sizeof(LOCAL_DELAYS)/sizeof(int); dloop ++ )
     state = !state;
     digitalWrite(LED_BUILTIN, state);
     // wait for a second
     delay( LOCAL_DELAYS[dloop] );
void scan_networks()
  Serial.println("Scan start");
  // WiFi.scanNetworks will return the number of networks found
  int n = WiFi.scanNetworks();
  Serial.println("Scan done");
  if (n == 0)
    Serial.println("no networks found");
  else
    Serial.print(n);
    Serial.println(" networks found");
    for (int i = 0; i < n; ++i)
      // Print SSID and RSSI for each network found
      Serial.print(i + 1);
      Serial.print(": ");
      Serial.print(WiFi.SSID(i));
      Serial.print(" (");
      Serial.print(WiFi.RSSI(i));
      Serial.print(")");
      Serial.println((WiFi.encryptionType(i) == ENC_TYPE_NONE)?" ":"*");
      delay(10);
  Serial.println("");
void loop()
  do_blinking();
  scan_networks();
Now we have binary ready, lets open terminal and observe how it goes:
  1. Power down ESP8266
  2. Prepare shell to run program, but do not run it yet:
    1. platformio run --target upload
  3. Power up ESP8266 and press the button to boot the ESP to programming mode
  4. Run the command above - after programming succeeds, power down the board.
Now we are all set, power up the board and see the serial line for the wifi network listing:
  1. Open cutecom, settings are 115200-8-N-1 - port is /dev/ttyUSB0
  2. Power up the board, no button pressed
  3. Observe blinking
Resources:
