3D Printers are getting faster, but longer hotends are harder to manage and the CHT doesn't scale much past a volcano meltzone. Here's a geometry that should scale, and testing indicates a flow improvement of 50% over the typical spacer.
Made using a copper bolt, crappy drill press, and a jeweler's saw. You can make one too, so please share when you do a better job! And maybe help me come up with a clever name ;)
Names in the running (as commented):
- Xylem Nozzle - Xylem is the plant tissue water and nutrients are pumped through
- XHT (Xternal Heating Technology)
- Xtruder
- "X-Flow” or the “Cross Flow”
Details
Most details are in the video, including how to make it. I'll add details here as I continue experimenting.
Components
1×
1 M6x20 Copper bolt
1×
Jeweler's Saw and blades
Use the biggest blade
1×
Drill Press
1×
10-15 Degree CNC V Bit
Aliexpress: (Do Degree10-0.1 for 10 Degree and 0.1mm tip) https://www.aliexpress.us/item/3256805260800615.html
1×
~0.7mm PCB Drill Bit
Size is approximate. Just make sure it fits your blade. Aliexpress: https://www.aliexpress.us/item/3256805429029496.html
