The basic idea for receiver section modification is quite simple. The original FM transceiver, not limited to IC-2N consisting double conversion with IF 10.7 MHz and 455 kHz. The local signal for the first mixer is generated by PLL. In deed if we make it from scratch, even now this signal generation is a headache but we can simply utlize in the modified CW receiver. After the 1st mixer, frequency is again converted to 455 kHz. This conversion and FM detection (F-V conversion) is mostly performed by super best seller IC, Motorola MC3357, 3359, or 3361. For second IF signal generation, 10.245 MHz oscillator is prepared by the crystal element. Here if change this frequency to , for example, 10.6985 MHz, the second mixer will work as product detector, and directly demodulated signal will be obtained. This way is, indeed, not new and in 80's 90's DIY receiver utilized for its simplicity, but I could not find "modification" in the any website....
microwavemont
mircemk
michal777
