• Shifting development to ESP32 board
    Jeff V4 days ago 0 comments
    I've had a LOT of difficulty bridging the gap between React Native BLE PLX library and the NRF52840 board in terms of sending data from a phone app to the board.
    After a bunch of looking around, it looks like I'll have more luck finding examples for an ESP32 based board, such as this awesome writeup: https://www.cjoshmartin.com/blog/bluetooth-low-energy-ble-with-react-native-and-arduino
    I'm going to try to set up a "characteristic" that I can then "write" to so that I can send a packet of information to the device.
    And while I'm not sure, it looks like the timer I had running on it previously with no issues stops after 2 seconds on the Adafruit ESP32-S3 board.
    I will update when I have news!
  • Progress made in companion app
    Jeff V09/06/2024 at 13:56 0 comments
    I've made some progress on the companion app thanks to this nice tutorial from expo that I've linked before: https://expo.dev/blog/how-to-build-a-bluetooth-low-energy-powered-expo-app
    It provides not only the finished code for the tutorial, but some started code to follow along as well.
    Strictly speaking (not sure if that's the right phrase), this tutorial is very similar to what I'm trying to accomplish with this project: a way for people to start with an idea for a Bluetooth smart device that connects to a phone app.
    I also added an objective for myself to receive data from the watch. In terms of an open source project someone can pick up and run with, this would be a good thing to have available as a starting point.
  • Quick Update: Back to Expo and React Native
    Jeff V08/31/2024 at 15:37 0 comments
    I am back to using Expo and React Native, for three reasons: 1) Expo is an easier way for me to generate apps for both Android and iOS, 2) I'm familiar with React and React Native, and 3) I actually got an app to work, and there may be hope yet.
    I had success getting a sample project to work with this post: https://blog.theodo.com/2023/07/ble-integration-for-rn-apps/
    Long story short, I did not use EAS to make a package then use on my phone, I used USB debugging. It didn't QUITE do what I wanted, but 1) it didn't crash and 2) once I manually turned on bluetooth on my phone, it popped up the bluetooth selection menu. I also had to use Node 16 due to this setup using an outdated SSL setup.
    I also found this blog post on the Expo web site I'm going to try to get working: https://expo.dev/blog/how-to-build-a-bluetooth-low-energy-powered-expo-app
    The main goal is to make an Android app (for now) that connects via bluetooth to my homemade smart watch.
  • Update, trying a native Android app
    Jeff V08/25/2024 at 03:23 0 comments
    I had trouble getting a Bluetooth app to work with Expo going to Android, so I'm going to try making a native Android app. I figure it doesn't matter if I submit the app, so I don't need Expo's system to do that.
    The main point is to make an app people can download and use, even if they have to build it and install it themselves.
  • Project objective progress
    Jeff V08/13/2024 at 16:17 0 comments
    To give an idea of what I'm trying to accomplish with this project, here are the epics I have thus far, and their completion rates
    watch responds to bluetooth
    100%
    create and publicize code respository
    (both arduino and react native app)
    100%
    make a simple bluetooth app in react native
    that watch responds to (all mock data)
    25%
    functioning physical watch buttons
    20%
    send time to watch via bluetooth
    send display to watch via bluetooth
    receive data coming from watch
    full test of watch functionality0%
    compartmentalize watch code for easy
    add/removal of functions
    code cleanup and possible unit tests0%
    PROJECT COMPLETE
  • Success connecting to Adafruit app
    Jeff V08/13/2024 at 05:12 0 comments
    Short update, I successfully copied some older Arduino code to connect the Feather board to the Adafruit bluetooth app, and the buttons on the controller (1 through 4) come through just fine, so it has basic bluetooth connectivity working.
    I wanted to post a picture of it, but since the display wipes after the button is released AND I am holding the phone taking pictures, not doable.
    The next challenge has two main parts
    - Make a basic phone app with the ability to connect to the board
    - Have that app send data that can be read by the board and acted on. For initial proof of concept, I will try to have it send the same data that the Adafruit app is sending, with a stream of "B4949" for "button 1 pressed", "B4948" for "button 1 released" and so on.
    Note the use of ascii numbers for both the number of the button and the status of the button, with 48 being zero and 49 being one.
    To some people reading this, this is very basic stuff, but it's a learning experience for me, and possibly for other people reading this very post.
  • progress report
    Jeff V08/12/2024 at 17:00 0 comments
    forgive the lack of formality e.g. lack of proper sentence grammar or capitalization. im writing this more or less free thought so i can get it down and post the update while i have to do my regular job
    current progress:
    to be honest, other things have been keeping my attention (this is a side project/hobby after all), so not much progress in the last couple of weeks. however, i have made a mock kanban in google sheets with the following epics.
    watch responds to bluetooth:
    the smart watch response to the adafruit bluetooth app
    make a simple bluetooth app that watch responds to:
    making a very pared-down version of the adafruit bluetooth app that the smart watch responds to. my initial plan is to use react native so it can port to both android and ios, but failing that, i will make it in android, which is simply my preference for now
    get watch buttons working (mock data):
    1) mode select button: change between time, timer, and display
    2) action button: executes simple action for each mode
    send time via bluetooth:
    simply have the watch set its time via the bluetooth app
    send display via bluetooth:
    whatever text is set in the app, it is synced to the device. see note below
    compartmentalize watch functions:
    toward the goal of making this easy for people to pick up and use, modify the smart watch code so that people can add or remove their own functions easily and cleanly
    note on the "display" mode: this function may seem odd or out of place. i admit this open smart watch project is a stepping stone for a different project, but this way not only can i make what i need, but others can possibly benefit by my documentation here.
    things i need to do for this project
    - provide images / code / screenshots of current progress
  • Note: changing project aim
    Jeff V07/31/2024 at 20:42 0 comments
    Noting that I shifted the overall aim of this project to include a smart phone app to connect to a simple Arduino smart watch, so people can take that and run with it.
    I am open to other technologies (e.g. ESP32 for the board and Gadgetbridge for the app)
    Some links to places I've looked that had more information and resourcres:
    Gadgetbridge
    Asteroid OS
    Open SmartWatch
    ElectroNoobs - SmartWatch Firmware v2.0 - Some Arduino code I may utilize
  • Initial hardware profile
    Jeff V07/18/2024 at 22:58 0 comments
    My initial work uses the following hardware
    - Adafruit Feather nRF52840 Express (https://www.adafruit.com/product/4062)
    -- is discoverable by BlueTooth
    -- has a Stemma connector, which I eventually abandoned
    -- can connect with a battery
    -- can recharge that battery
    - Adafruit Grayscale 1.5" 128x128 OLED Graphic Display (https://www.adafruit.com/product/4741)
    -- good screen size
    -- Stemma connector
    - Lithium Ion Polymer Battery - 3.7v 500mAh (https://www.adafruit.com/product/1578)
    -- about the size of a US quarter, about 4mm thick, which is a decent small size
    -- pretty good capacity
    -- connects easily to the Feather board
    I plan to try to either use a single board for bluetooth and magnetometer functionality, or get two smaller boards if the combined board has too many extras.
    This board has both, but might end up having too much extra stuff (and it's $15 more than the other Feather): Adafruit Feather nRF52840 Sense (https://www.adafruit.com/product/4516)
  • Initial desirables
    Jeff V07/12/2024 at 22:19 0 comments
    Here is my current list of desirables
    - bluetooth discoverability: so any phone can connect to it and send it data (two way communication NOT required)
    - bluetooth communication including
    -- phone sends message to display watch, not necessarily SMS
    - magnetometer to track movement like gestures like left/right and show compass direction
    - utilization of a battery with display of battery remaining
    - ability to recharge battery via typical USB
    - display that turns on with a button press (for the first version)
    - watch functionality including
    -- timer
    -- stopwatch
    -- set time and date
    -- show current month calendar
    -- change display between digital and analog
    - display
    -- I've played with the basic types of displays like ST7789
    -- I would prefer a screen that's about 1 1/2 inches (38 mm) in diagonal
    -- I would love high pixel density, but I don't know what I could use or the downsides
