Unit Tests Complete
A project log for Star Trek Communicator Badge
In the true spirit of Star Trek, this communicator badge is completely autonomous, while fitting in the form factor of an original badge
JoeJoe 02/27/2017 at 04:300 Comments
Every sub-system is working now that the Teensy is up and running. I developed some simple unit tests to help debug the board and soldering.
The test code can be found here and used to get your own communicator debugged: https://cdn.hackaday.io/files/19700842844800/Unit Tests.zip
The final step: Get the RF module up and running. First, I will verify the connections with some existing breadboard code. After that, the more major task will be to merge both transmitter and receiver code into the same file.
