Communicator_Code_BETA_v2.zipBeta version of communicator code supporting unlimited nodes. streaming library now inherits original lowPowerLab library. Exact RFM69 library now included to avoid version incompatibility.Zip Archive - 540.23 kB - 11/27/2017 at 00:35 |
PacketStreamDemo.zipA demo of a packet stream instead of a bit stream. This is way more reliable.Zip Archive - 575.23 kB - 07/01/2017 at 16:55 |
RFM69_old.zipUse in place of RFM69 library with Communicator_Code_BETA_v1Zip Archive - 218.41 kB - 04/04/2017 at 02:20 |
Communicator_Code_BETA_v1.zipBeta version of communicator code with two unique nodes. streaming library now inherits original lowPowerLab library.Zip Archive - 53.08 kB - 03/28/2017 at 00:53 |
communicator_v2p2.schPower switch now controls enable pin of regulator so switch is not in power path.sch - 292.67 kB - 03/26/2017 at 22:54 |
communicator_v2p2.brdPower switch now controls enable pin of regulator so switch is not in power path.brd - 150.95 kB - 03/26/2017 at 22:54 |
Video_Demo.zipCode used in demo video. Tested and working with 915MHz RadioZip Archive - 12.07 kB - 03/13/2017 at 02:01 |
RFM69_Stream.zipRFM69 Library from Low Power Lab, modified to allow audio streaming.x-zip-compressed - 199.73 kB - 03/06/2017 at 16:49 |
communicator_v2p1.schNew board with power switch and tap detector interrupt on deep-sleep enabled pinsch - 291.75 kB - 03/01/2017 at 05:57 |
communicator_v2p1.brdNew board with power switch and tap detector interrupt on deep-sleep enabled pinbrd - 141.56 kB - 03/01/2017 at 05:56 |
Unit Tests.zipArduino test code for each sub-system , mic, speaker, accelerometer.Zip Archive - 19.58 kB - 02/27/2017 at 04:25 |
tng_chirp_clean_32000_u8bit_trimmed.wavChirp sound that is played when communication is initiatedWaveform Audio File Format (WAV) - 9.81 kB - 02/27/2017 at 04:00 |
Communicator_Demo.zipArduino demo code that puts one Teensy LC in Audio Transmit mode and another in Audio Receive mode.Zip Archive - 224.88 kB - 02/21/2017 at 02:53 |
MOUSER_Invoice_scrubbed.pdfDetailed Mouser invoice showing exactly what parts to get. Bootloader chip needs to be purchased from PRJC directly.Adobe Portable Document Format - 852.62 kB - 02/17/2017 at 07:27 |
communicator_v2.brdNew Board Layoutbrd - 138.53 kB - 02/17/2017 at 07:18 |
communicator_v2.schNew Board Schematicsch - 280.76 kB - 02/17/2017 at 07:18 |
Bitrate Calculations.xlsxSpreadsheet of bitrate calculations and achievable bandwidthssheet - 5.17 kB - 02/03/2017 at 04:40 |
communicator.schEagle Schematic of Communicator Badgesch - 280.76 kB - 02/03/2017 at 04:04 |
communicator.brdEagle Layout of Communicator Badgebrd - 134.07 kB - 02/03/2017 at 04:04 |
