Mioke80 ISO / ANSI 99 Key ~80% Keyboard
Another Open Hardware Keyboard using QMK Firmware
Another QMK based Keyboard (not a copy, a new keyboard design).
- The schematic (kicad) is pretty much complete 99.9%...
- QMK code tested and working on BlackPill (STM32411)...
- More to do in relation to QMK such as layers etc...
Kicad references: KoBuss's and Noah Kiser's youtube tutorials and git pages, both are recommended viewing. Kicad and QMK files are included in my git repo.
The 99 keys include everything except number pad, plus an additional ten macro/media keys.
ISO and ANSI versions...
Please check Project Log for updates...
Hardware: Micro, Keys, etc...
For now, I went with the STM32F072CBT6 as I have a few in stock, might try other chips later.
We could also use other Micros with more GPIO's to remove the need for diodes but I don't know which Micros QMK supports.
For the keys/switches, I went with MX as I also have quite a few. I also went with the hot-swappable option.
Tools:
  • Kicad version 8.0.3+1, release build...
  • Plugins: KLE Placer (saves so much time with layout, a must have).
  • QMK Configurator
Other references:
keyboard-layout-editor.com
Keys: 99 Keys, including 5 Dedicated Macro Keys and 5 Media Keys.
final_ansi_keyboard_layout.json
This is the Keyboard Layout Editor code for V1.0 ANSI Go to http://www.keyboard-layout-editor.com and paste it raw data section... File has change, check repo...
JavaScript Object Notation (JSON) - 1.08 kB - 08/09/2024 at 18:04
Download
final_iso_keyboard_layout.json
This is the Keyboard Layout Editor code for V1.0 ISO Go to http://www.keyboard-layout-editor.com and paste it raw data section... Please see my git repo for up to date file... File has change, check repo...
JavaScript Object Notation (JSON) - 1.09 kB - 08/09/2024 at 17:05
Download
  • 1 × Micro (In Final Version) STM32F072CBT6 LSCS # C81720
  • 1 × Blackpill Module (Test Version) STM32F411 Blackpill Dev Board
  • 1 × Diodes (100) Diode_SOD-123 LSCS # C81598
  • 1 × WS2812B (99) LED WS2812B-2020 PLCC4 2.0x2.0mm LSCS # C965555
  • 1 × Hot Swappable Connectors (99) CON_HS_MX LSCS # C5184526
View all 8 components
  • BlackPill Prototype Built
    Michael O'Toole09/10/2024 at 22:19 0 comments
    BlackPill prototype build testing:
    I received the five prototype boards today and set about building a test board (blackpill version), here are the changes required.
    1. Minor edit of code (I had two keys reversed), fixed for the next phase (discrete board build)...
    2. As I used an ISO layout, I had to change one QMK key code (replace KC_TILDE with KC_NUHS)...
    Assembly notes and comments:
    The diodes and hot-swappable sockets were pretty easy so no issues with these, as for the RGB leds, I didn't bother, perhaps another time but will change these out for an easier to solder version. That was all the changes for general keyboard functionality, it works perfectly. Next the code for the macro keys, RGB and rotary encoder...
    I have two excellent AKKO keyboards, if I can achieve similar results to these I will consider it a success ;)
  • Building with tiny SMD parts
    Michael O'Toole09/08/2024 at 17:44 0 comments
    I've received parts for the BlackPill prototype version and to be completely honest they are tiny, perhaps too tiny.
    The diodes will be difficult enough being there are 99 of them and no stencil, but I'm not at all confident I can solder the current RGB LEDs even with the stencil supplied, they are simply too small for comfort and my eye sight is not good.
    I will give it a go but may have to update the RDG leds from WS2812B to SK6812-E  as they mount on the back side (allowing one stencil for everything), and they are easier to hand solder.
  • Update to 10x10 Matrix
    Michael O'Toole08/22/2024 at 13:39 0 comments
    Switches to 10x10 matrix (20 free pins required for matrix, as opposed to 24 previously). This gives me all the pins I required including the flash option to store macros (plus one spare pin).
    Smaller keyboards with fewer keys probably wont have this issue. The STM32F4xx (48 pin) should handle a full size keyboard using a 10x11 matrix but that's for another time...
    As I said previously, I'm building with the Blackpill to test everything prior to building with discreet components. Quite a learning experience, especially trying to route a 10x10 matrix, not an easy task on two layers, so I switched to four.
    Of course I had to modify the code and keyboard_layout,json etc., but that bit is easy enough. Some more checking of the Kicad file, then off to PCBWay...
    keyboard_layout.json (from: keyboard_layout_editor.com)
    [{f:3,a:7},"Reset",{x:0.25},{"p":"DCS","a":7,"f":4,"fa":[5]},"Esc",{"x":1},"F1","F2","F3","F4",{"x":0.5},"F5","F6","F7","F8",{"x":0.5},"F9","F10","F11","F12",{"x":0.25,"f":3},"PrtSc","Scroll Lock","Pause"],
    [{y:0.25,"f":6},"M1",{"x":0.25,"a":5,"f":5},"¬\n`","!\n1","\"\n2","£\n3","$\n4","%\n5","^\n6","&\n7","*\n8","(\n9",")\n0","_\n-","+\n=",{"w":2},"Backspace",{"x":0.25,"a":7,"f":4},"Insert","Home","PgUp"],
    [{"f":6}, "M2",{x:0.25},{"f":6,"w":1.5},{"f":6,"w":1.5},"Tab","Q","W","E","R","T","Y","U","I","O","P","{","}",{"x":0.25,"w":1.25,"h":2,"w2":1.5,"h2":1,"x2":-0.25},"Enter",{"x":0.25,"f":4},"Del.","End","PgDn"],
    [{"f":6}, "M3",{x:0.25},{"f":6,"w":1.75},"Caps","A","S","D","F","G","H","J","K","L",":","@","~",{"x":1.5},"V↓"," >","V↑"],
    [{"f":6}, "M4",{x:0.25},{w:2.25},{"w":1.25},"Shift","|","Z","X","C","V","B","N","M","<",">","?",{"w":2.75},"Shift",{"x":0.25},"<<",""," >>"],
    [{"f":6}, "M5",{x:0.25},{w:1.25},{"w":1.25},"Ctrl",{"w":1.25},"Menu",{"w":1.25},"Alt",{"p":"DCSSPACE","w":6.25},"",{"p":"DCS","w":1.25},"Alt",{"w":1.25},"FN",{"w":1.25},"Menu",{"w":1.25},"Ctrl",{"x":0.25},"","",""]
    From keyboard_layout_editor.com my Ayla80 99 key version.
    Note for above image: Might increase left shift from 1.25 to size to 1.75, then move \ to far right (before right shift) and reduce right shift from 2.5 to to 1.5. This might make more sense...
    3D Image
    New 10x10 matrix (20 pins) version
  • STM32F411 Blackpill Version
    Michael O'Toole08/18/2024 at 00:53 0 comments
    Before committing to ordering the boards and associated costs, I though I better test the keyboard circuit design. I removed all of the hard to solder components and replaced them with a BlackPill Dev Board (exactly the same electronics as my board).
    This only leaves the larger components, Diodes, RGB Leds and Hot-swappable connectors which most of us should be able to handle with a good soldering (I use a KSGER which I highly recommend).
    This extra step (proof of concept) before spending money only to find I made a mistake with the layout, code or both, is not essential but realistically it's probably necessary considering the complexity involved.
    So to conclude, the new board is basically the same except we now use a Blackpill for the electronics and it now includes a rotary encode (for volume and RGB dimming). It should be much easier to build and program...
    Once testing is done (not sure if some of GPIO's I used are problematic), I can continue with the embedded version... See project log for update, there are a few...
    Image:
    Mike
  • Updates: Stabilizer & Footprints
    Michael O'Toole08/15/2024 at 15:36 0 comments
    Lest I forget, I added another stabilizer (2U) for the Enter Key, also, edited marbastlib-mx:SW_MX_HS_CPG151101S11_xxx  to include graphics to align the RGB led (had to eyeball the placement as I can't find and official dimensions).
    More...
  • QMK Code Testing
    Michael O'Toole08/12/2024 at 11:18 0 comments
    From the limited experience I have with QMK, it  appears to be a little more Windows / Mac centric, case in point, the QMK Toolbox (recommended GUI), only contains Windows and Mac programs, for Linux it's pretty much CLI (command line interface) all the way...
    There's a lot of quality documentation but I could not find a basic walk through on getting a newly designed keyboard up and running, however, I did find lots on setting up or modifying an existing designs which helped...
    *Will add link to the instructions I used that did not work (left all five test board stuck in DFU mode) as soon as I find it again*
    Test Board used: STM32F401/411  BlackPill
    Process:
    • CD to your qmk_firmware directory
    • qmk new-keyboard ... follow instructions
    • make ayla_411:default
    • ./flash.sh ayla_411_default.bin
    The flash.sh is available on git, not essential but useful...
    See: https://github.com/phpbbireland/mioke80/tree/main/qmk/ayla_411
    Essentials:
    https://docs.qmk.fm/hardware_keyboard_guidelines#naming-your-keyboard-project
    https://docs.qmk.fm/newbs_getting_started
    https://docs.qmk.fm/flashing
  • Media Options
    Michael O'Toole08/09/2024 at 17:01 0 comments
    For this version I will use keys to control audio... Volume Up/Down, Next/Previous Track, Play/Pause.
    In the next version I will use a Rotary Encoder for audio and RGB brightness...
  • Git Repository
    Michael O'Toole07/25/2024 at 19:22 0 comments
    I added the Kicad file to my Git Repository, mind you, some footprints and 3d images are mixed sources, you may have to add your own or re-link them...
  • Adding RGB
    Michael O'Toole07/25/2024 at 15:52 0 comments
    To be added...
    RGB (may switch to four layer PCB if routing proves difficult)... completed
    Rotary encode primarily for volume and brightness control...
View all 9 project logs
Michael O'Toole wrote 07/26/2024 at 13:52 point
Will correct it's 8.0.3... simple typo this time, but I can do this on occasion...
Ken Yap wrote 07/26/2024 at 00:12 point
>Kicad version 8.3
You actually mean 8.0.3. 8.3.x is highly unlikely. The next major release next year will be 9.0.0. The numbers are major release, minor release, and patch level. Since 5.1 there have been no minor releases so that number is 0. All patch levels for a given major and minor number are compatible. The current release is 8.0.4 so the patch level is 4.
