E-Pot Prisma
3D Printed planter ready to integrate the Smart Plant powered by integrated solar panels
jonJon
E-Pot Prisma is a 3D printed planter that matches geometric elegance with modern technology. Featuring intersecting planes design and an easy 3d printable design, it can host the Smart Plant board, providing an integrated solution with IoT capabilities, an e-paper display, measurements of soil moisture, ambient light, air humidity, and temperature and solar charging. Additionally, it's designed with integrated piping guidance, supporting 6mm pipes plugs so water irrigation can be scheduled through the Smart Garden board. It can be placed over an horizontal surface or as part of a wall-mounted vertical garden.
Base_1.stl
Base design number 1. It integrates horizontal holes for the screwed quick 6mm (Outer Diameter) plugs and 3d printed internal guidance for water distribution. It's the red design in the pictures.
Standard Tesselated Geometry - 4.14 MB - 07/28/2024 at 15:28
Download
Base_2.stl
Base design number 2. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution.
Standard Tesselated Geometry - 811.18 kB - 07/28/2024 at 15:28
Download
Base_3.stl
Base design number 3. It integrates vertical holes for the screwed quick 6mm (Outer Diameter) plugs. No integrated water distribution. The flushing system can be added with a 6mm flexible pipe. It's the green design in the pictures.
Standard Tesselated Geometry - 924.50 kB - 07/28/2024 at 15:28
Download
Hanger.stl
Hanging part for the rear
Standard Tesselated Geometry - 105.87 kB - 07/28/2024 at 15:28
Download
Top.stl
Upper cover to protect the electronics
Standard Tesselated Geometry - 221.28 kB - 07/28/2024 at 15:28
Download
  • 1 × Smart Plant https://hackaday.io/project/189596-smart-plant
  • 2 × PC6-02 Pneumatic Fitting 1/4", Pneumatic Connector 6mm.
  • 3 × Solar panel 5V 68x37mm
