• Servo Motor Assembly
    h2w6 days ago 0 comments
    The board assembly with servo motor and mounting bracket is shown in the figure below. There are a total of three such motors in the tape recorder.
  • Servo Motor Board
    h2w09/10/2024 at 11:03 0 comments
    The final solution of the servo motor control board is based on the following solutions.
    1. Minimum number of pins on the connector from the control board. In which besides `GND` and +24V, there is a movement direction signal `CW` or `CCW`. And an end-of-motion signal `END`. The END signal should allow the control system to register error situations -- for self-diagnosis.
    2. The control board must control the 24V voltage to quietly turn on the system.
    3. The board must not contain a micro-controller.
    Despite the simplicity of the board, I performed a PI/SI simulation to evaluate the result.
  • Considering Cross Board Design
    h2w08/04/2024 at 13:42 0 comments
    If 32 pin connectors are used, the pins will be more than sufficient. I assume to divide all pins into three groups.
    1. Power - power and ground lines of analog circuitry and control and switching system: -+15V +5V. In this case, use both sides of the connector, that is, two pins per signal.
    2. Control - control lines from components located on the motherboard. Each such line can include a relay. All control lines occupy a fixed number of pins on all connectors. However, while some of them come from one output per board (shared), others are dedicated exclusively to a particular board (specific).
    3. Special - the signal lines of a specific board. They are organized differently for different boards.
    In addition to components for generating control signals, the motherboard has its own set of relays for switching specific signals of the tape recorder.
    For example HF bias generator. It does not use -15V however its pin-out in the power supply section is the same as all other boards.
    The control section only uses specific signals, the other pins remain unused.
  • Servo motor board design considerations
    h2w08/02/2024 at 10:58 0 comments
    A board from another developer uses a three-pin connector. This is a very simple and inexpensive solution. The pin-out of the connector is shown below.
    1. GND - the ground for power and signal
    2. +24V - the power for the servomotor
    3. DIR - the direction signal: 0 - rotate CW, 1 - rotate CCW
    The motor stops by itself when the marker reaches the optical sensor.
    The disadvantages of this are:
    • The control controller has no status from the servo motor;
    • If the device is suddenly de-energized, the servo motor will start moving in the default direction when power is restored. This somewhat makes the process of powering up the device a bit daunting for the user
    Solution 1 - With RS485
    For more complete control you can use RS485 interface. Then there will be a pinout.
    1. GND - power ground
    2. +24V - power
    3. A - RS485
    4. B - RS485
    However, this will require a microcontroller and interface converter to be installed on the board. This makes the construction more expensive.
    Solution 2 - With I2C
    It will be a little cheaper if you use I2C interface.
    2. +24V - power
    3. GND - signal ground
    4. SCL - I2C
    5. SDA - I2C
    Solution 2 - Passive
    In this case only the motor driver is installed on the board. Then the pinout will be as follows.
    2. +24V - power
    4. M1 - motor in1
    5. M2 - motor in2
    6. S1 - sensor 1
    7. S2 - sensor 2
    Conclusion
    Tough choice considering the connectors and wires cost their money too. However, the RS485 option looks like the most noise-protected and therefore reliable option.
  • Considering DIN connectors
    h2w07/30/2024 at 08:26 0 comments
    The Soviet MRN-14 connectors were great, but are obsolete today. The use of DIN41612 will require a slight modification to the chassis. However, it is not important if you build your own tape recorder from scratch.
  • UV Meter Initial Release
    h2w07/30/2024 at 07:57 0 comments
    The level indicator repeats Leoniv's design (link below) but is implemented in Altium. I plan to remove everything unnecessary from the board. One of the devices to be removed is a parallel port, which is designed to read the state of the tape recorder and display on the indicator. In my case, the control will be carried out exclusively through R485.
    The indicator firmware will be completely reimplemented.
