LCD Dashboard for Raspberry Pi (System Monitor)
Hardware System Monitor for Raspberry Pi on LCD (Open Source)
Public Chat
Unique hardware dashboard for Raspberry Pi 4 and Raspberry Pi 5 with 3D model for Argon Neo 5 enclosure. This project allows you to install a color LCD screen in the Argon Neo 5 case and display the following system parameters: - CPU Usage - CPU Temperature - RAM Usage - SWAP Memory Usage - Storage Usage - IP / Hostname - Network Traffic I have designed my 3D model of the enclosure cover with a space for the display. The assembly is simple, using snap-fits, with no tools required. The models are open-source so that anyone can print them on a 3D printer. The source code is also open-source, allowing users to add new functionalities, customize it to their needs, or add support for new displays. I recommend printing with PETG filament due to the Raspberry Pi's high operating temperatures. To ensure the snap-fits print correctly, enable 'supports everywhere.' Use 1.69" LCD with ST7789V2 Driver - Waveshare 24382 - Seeed Studio 104990802
This project is part of the Web3Pi initiative, which enables the automated deployment of a full Ethereum node on a Raspberry Pi.
https://www.web3pi.io/
Argon_Neo_5_Top_LCD.stl
3D model - Argon Neo 5 enclosure cover
Standard Tesselated Geometry - 186.51 kB - 08/01/2024 at 10:48
Download
  • 1 × 1.69" LCD Waveshare 24382 1.69" LCD display with ST7789V2 Driver (https://www.waveshare.com/1.69inch-lcd-module.htm)
  • 1 × 1.69" LCD Seeed Studio 104990802 1.69" LCD display with ST7789V2 Driver (https://www.seeedstudio.com/1-69inch-240-280-Resolution-IPS-LCD-Display-Module-p-5755.html)
  • 1
    Instructions are at Github
    https://github.com/Web3-Pi/raspberry-pi-lcd-dashboard
    Requirements
    • Python >= 3.9
    • Run on Raspberry Pi 4 and 5
    • Raspberry Pi OS or Ubuntu
    • SPI interface enabled
    • 1.69" LCD display with ST7789V2 Driver
    • Waveshare 24382
    • Seeed Studio 104990802
    • (Optional) 3D printed model of Argon Neo 5 cover
    • (Optional) Argon Neo 5 enclosure
    Assembly
    1. Connect wires
    Connect the display to the Raspberry Pi according to the diagram below.
    The colors of the cables may vary depending on the supplier and batch. Focus on the function and pin number, not the color.
    The diagram is valid for Raspberry Pi 4 and Pi 5
    If on Raspberry Pi 5 your LCD backlight is flickering connect `BL` to `3.3V PIN 17`
    2. Mount display module
    Mount the display in the printed enclosure cover. The display is held in place by four clips. Make sure all 3D printing support residues are removed and the surface to which the display adheres is flat. Install the display by sliding one side under the clips first, then pressing the other side down. Do not use excessive force to avoid damaging the display. The display should fit in easily.
    Since each 3D printer may be calibrated differently, it may be necessary to adjust the scale of the 3D model in the slicer software before printing. Our prints are done on Original Prusa i3 MK3S+
    3. Mount enclosure cover
    Mount the enclosure cover and secure it with two screws. Make sure to arrange the cables inside the enclosure so they do not obstruct the fan and minimize interference with cooling.
    Installation
    To enable the display, the SPI interface must be enabled.To do this, execute the following command and then reboot the device:
    sudo sed -i '/^#dtparam=spi=on/s/^#//' /boot/firmware/config.txt
    sudo reboot
    Download the repository.
    sudo apt-get -y install git
    git clone https://github.com/Web3-Pi/raspberry-pi-lcd-dashboard.git
    Then, you can run the program as a service. The program will start automatically with the system startup.
    Alternatively, you can run it once. The program will stop when you close the console.
    Run as a service - (recommended)
    cd raspberry-pi-lcd-dashboard
    chmod +x *.sh
    sudo ./create_service.sh
    To stop the program, execute sudo systemctl stopdashboard.service
    To uninstall the service, execute sudo ./remove_service.sh
    or run one time
    If you do not want to run the program as a service, you can run it once.
    Note: Do not use both methods simultaneously.
    chmod +x *.sh
    sudo ./run.sh
    To stop the program, press Ctrl+C.
    Customization
    In the file `dashboard.py`, there is a flag SHOW_PER_CORE that determines whether the CPU usage percentage should be in the range of 0-100% or 0-400%.
    0-400% represents the sum load of each core in the Raspberry Pi.
    # Choose how to display CPU usage percentages
    SHOW_PER_CORE = False
    # False = [0 - 100%]
    # True  = [0 - 400%]
    note: Restart the service after making changes.
    sudo systemctl restart dashboard.service
    3D Model
    The models are free, so anyone can print them on a 3D printer.
    3D Printing
    We recommend printing with PETG filament due to the Raspberry Pi's high operating temperatures.
    To ensure the snap-fits print correctly, enable supports everywhere.
    Use a 0.4 mm nozzle.
    0.2 mm layer height or smaller.
    Our models are printed on Original Prusa i3 MK3S+
View all instructions
