Read the specs! My plate got rejected because the holes were too close to the edge and violated some DFM rules from the fabricator:
Dang, they were patient with me. With any luck the latest iteration goes through; I moved a few taps in a bit where I could, and changed the servo mounts to non-tapped slots. Hooray for helpful vendors. I'm so used to checking design rules for PCB vendors; maybe I didn't think about it much here because I'm used to bending the waterjet cutter to my will and probably making non-conforming parts in the process. Slow down, do engineering, etc.
zakqwy
