PatchMate:Level Control Adaptor
Breadboard/Chip style format synth adaptars
0 followers
-Features-
•Breadboard Compatible
•Uses common Euro-rack 9mm Potentiometers and PJ301/PJ398 Eurorack 3.5mm Jacks
•Dual use Badge as a Input/output Interface for breadboard or as a Passive Level Control Adaptor for Eurorack gear.
•Jumpers to Change between Level Control and IO Connecting the jacks to mono.
•Test hooks for looking at Inputs/Outputs
•Optional Male/female 2.54 headers for Input Signals/Ground
•Silkscreen place to write what the type of Input/Output Jack is Labeled
-Why I made it-
I wanted a good Interface for using common eurorack 3.5mm Jacks on a standard breadboard. So I made this multi purpose PCB badge. It also Jumps the +/Ground Rail from both sides of the PCB so no jumper wire is needed.
Features
*Breadboard Compatible Can connect Left and right Power/Ground at the top of a breadboard
*Uses common Euro-rack Potentiometers and PJ301/PJ398 Eurorack 3.5mm Jacks
*Dual use Badge as a Input/output Interface for breadboard or as a separate Passive Level Control Adaptor for Euro rack gear.
*Test hooks for looking at Inputs/Outputs
*Male/female 2.54 headers for Input Signals/Ground
*Jumpers to Change between Level Control and IO Connecting the jacks to mono.
View project log
