log 4: Schematic and plastic
A project log for Ma'Tok staff weapon from Stargate
A staff weapon made from wood with actions, lights and projectiles
shlonkinshlonkin 02/21/2017 at 13:250 Comments
Here's an electrical schematic. It really is very simple. I wanted to have another one or two LED rows, but I want separate pwm for each one and the servo library eats up two of my pwm pins. Oh well, four will still look cool.
I have been making the various sections of the staff. I tried applying a heat gun to some 50mm pvc pipe for the decoration just behind the head. It worked out pretty well.
Then I tried to form the control section. Then I tried again, and again. The results were not so encouraging.
I decided to abandon the plastic idea and make something out of wood. The only reason I didn't do this in the first place was the need to bore a huge hole for the shaft. But It turns out a large auger bit is not as expensive or hard to handle as I thought. I glued up some scrap boards and put a hole through what will become the control section.
