Laser projector with 3 lasers (RGB) incident on an x-cube(dichroic) with galvanomirror
I've been experimenting with the setup trying to make the galvo movement as smooth as possible and for this i've been successful in implementing a triangle wave generator on the DAC with DMA, i've gotten the results and compared with the interrupt based output which was limited to 300 Hz, with DMA however i've tested the wave output to 200KHz, This creates many different opportunities for me. First i can rest assured that the microcontroller is not being the bottleneck and concurrent processing in the stm32 while the SCAN mechanism is running.
I've discovered that the DMA has callbacks which i can use such as half-complete or full-complete. This allows us to change the one half of the array while the other half is being output. this way we can keep the lookup table updated. but i don't think we will need this as we just need a constant scanning mechanism.
I've also gotten a bit better in the stm32cubeide, now i can use the debugging features such as live variables and use the debugger better. I also understand that an easy way to look for available functions is to look in the header file and use that. not everything is defined in reference manual or data sheet.
I faced a problem while generating the triangle wave with DMA on the DAC; the wave had some weird peaks showing
I tried to fix it by doing several things such as adding a bypass capacitor, low pass filter but it couldn't be fixed. in addition to the wrong waveform, the frequency it was showing was also wrong, almost triple of the calculated frequency. I then fixed it by changing the word size of the DMA from word to half word. this fixed the issue.
I've also gotten hold of some better lasers which i've connected the power supply to by directly connecting to it's + and - also i'm working on developing a holder for the laser. before we use kinematic mirror mounts which allowed to make minute adjustment in x and y direction. but since this new laser is larger we can't fit it in there.
The laser looks heavy stuff but it's just a slightly better laser than the usual pointer. I wouldn't be surprised if the same diode is used here as well.
Right now I'm looking into somehow triggering the 2nd dac used for Y axis steering when the X axis DAC triangle wave is completed by using the complete callback.
After implementing the code on hardware the following were the results:
I created a lookup table of around 100-256 samples with values increasing from 0-4095 to represent an incremental increase in the voltage of around (50-124px representing a pixel). Then that lookup table was fed to the DAC via Interrupt routine in stm32cubeide and also implemented on stm32duino with just a normal for loop to test the difference. However the results were almost the same.
The scanning done horizontally was going quite good it showed a straight line and i confirmed that it is working by slowing the scan speed of the galvo so i could see it jumping to each different pixel. The problem was that it took quite a bit of time coming from top to bottom as expected because the y axis dac was supposed to increment after the horizontal (x-axis) scan was complete. I deleted all delays but still results were the same.
It is my understanding that no matter what i do doing it through the CPU might be slow for whatever reason, maybe the DAC is being notified late or value executed late. I have my clock speed of the peripheral and system clock speed at 72Mhz (maximum available) but this is still the case. the following are my assumptions without looking too deep into it.
To estimate the time it takes to output a single value from RAM to the DAC using a for
loop on the STM32 F3 Discovery board, we need to consider several factors:
for
loop, including loading the value from RAM, and writing it to the DAC.But that is assuming that the galvo's can follow the speed at which signal is given. So i'm sure now that the microcontroller is not the issue. It has to be the bulky mirrors slowing everything down. I wouldn't be surprised if it skips a couple of values as it is reaching the specified position.
My galvo's are the generic ones sold in amazon but i got it from aliexpress, Looking at the specification it has the rating of 15kpps so that should give us around 66.67 microseconds for each step. now that's still not surprising, our whole sweep which was running at full speed completely taking around 11.1 microseconds, the galvo is being a bottleneck which is around 6 times slower.
In addition to that according to specifications my galvo can sweep an angle of +-20 degrees with an input signal range of +-5V, since my signal is only 0 - 3.3V that gives me an angle range of ≈6.6 degrees for the whole range. This is good because the smaller range it is the lesser momentum it will build and easier for it to put a stop to it's motion.
There seems to be a problem in my understanding because if the galvo's response rate is truly 6 times slower that means the galvo should not even jump to the next point, instead...
Read more »Well never a better feeling than what you thought might work actually works. After reading up more on some computer graphics turns out the mechanism with which i want to project and which was implemented on CRT tvs is called "Raster scanning" but i couldn't find any documentation of it or any work that had implemented this on galvos. after searching a bit more it turned out that this is a pretty common method and is usually hidden from public because i mean who even thinks about how characters are printed to the screen. I found some people utilizing windows.h api to print to screen from scratch and found some old commodore_64 era programs that used terminal as a screen. Most of all Javid from youtube with his game engine videos on command line helped alot.
Here is the code.
#include <stdio.h>
#include <unistd.h> // for usleep()
// Define the Pixel struct
typedef struct {
int x; // Position of the pixel in x
int y; // Position of the pixel in y
int dac; // Voltage value to be fed to DAC
int intensity; // Brightness level
int color[3]; // RGB color options
} Pixel;
// Define the Settings struct
typedef struct {
int pixelDelay; // Delay between drawing each pixel in microseconds
int gridSize; // Size of the grid (number of pixels per side)
} Settings;
// Hardcoded bitmap for the 8x8 grid with a 4x4 square in the center
// 1 represents pixels to be drawn (green), 0 represents non-pixels (red)
const int bitmap[8][8] = {
{0, 0, 0, 0, 0, 0, 0, 0},
{0, 0, 1, 1, 1, 1, 0, 0},
// Function to initialize the grid from the bitmap
void initializeGrid(Pixel grid[], int gridSize, const int bitmap[8][8]) {
for (int y = 0; y < gridSize; y++) {
for (int x = 0; x < gridSize; x++) {
int index = y * gridSize + x;
grid[index].x = x;
grid[index].y = y;
if (bitmap[y][x] == 1) {
// Pixel value
grid[index].dac = 99;
grid[index].color[0] = 0; // Green
grid[index].color[1] = 255; // Green
grid[index].color[2] = 0; // Green
} else {
// Non-pixel value
grid[index].dac = 0;
grid[index].color[0] = 255; // Red
grid[index].color[1] = 0; // Red
grid[index].color[2] = 0; // Red
// Function to print the grid with colors and simulate delay per pixel
void printGrid(const Pixel grid[], int gridSize, int pixelDelay) {
printf("Grid:\n");
// ANSI escape codes to set the text color
printf("\033[48;2;%d;%d;%dm", grid[index].color[0], grid[index].color[1], grid[index].color[2]);
printf(" "); // Print a space to represent the pixel
// Reset text color
fflush(stdout);
printf("\033[0m");
// Simulate delay between printing each pixel
usleep(pixelDelay);
printf("\n");
int main() {
Settings settings;
settings.gridSize = 8; // Size of the grid (8x8)
settings.pixelDelay = .2 * 1000000; // Delay between each pixel in microseconds (0.2 seconds)
// Define a grid to hold a single image
Pixel grid[settings.gridSize * settings.gridSize];
initializeGrid(grid, settings.gridSize, bitmap); // Initialize the grid from the bitmap
printGrid(grid, settings.gridSize, settings.pixelDelay); // Display the grid
return 0;
The raster projection I should say is working quite well. I've created each pixel to have position in the x,y a value which i'm calling dac value which is the actual voltage level where these pixels will correspond. For now these are just numbers. Then assigning each pixel intensity and colors. When i convert this to real galvo system i'll have to add in delta_v (voltage difference) and hope to calculate next pixel position with this. Then will first try to make it work with intensity. Possibly creating a shade of green laser along a line should be cool. The pixel delay or "Dwelling time" Is not just adding a delay here...
Read more »I'm pausing the experimental setup to plan the next steps:
Initial Approach: I'll begin by researching papers on similar laser scanning mechanisms. My goal is to synchronize laser activation with the galvo mirror's feedback, ensuring precise targeting. I plan to implement functions on a microcontroller (starting with C on a computer) to draw horizontal lines by specifying certain parameters. Greater control over these functions will help me understand and refine the system.
Planned Functionality:
Objective: The function will be integrated into the galvo's horizontal scanning mechanism, allowing it to draw lines while maintaining a fixed vertical angle. After completing a horizontal scan, the system will increment vertically and repeat the process. The idea is to synchronize the horizontal scanning and line drawing mechanisms, enabling the precise rendering of an image, such as a vector or bitmap, in a line-by-line fashion.
Here is how it should look like. say we are given an image which after being processed looks like a vector image or a bitmap to make it simple.
byte customChar[] = { B01110, B10001, B10001, B01110, B10001, B10001, B10001, B01110 }
All I have to do is when I know that the galvo is at the top vertical position i.e, top right (0,0) and scans horizontally towards right, it should go something like this
pixelTobePopulated()? DrawPixel(): skip();
The result should be a pattern like this: FTTTF (T for true, F for false). Initially, I'll hard-code a bitmap or vector image, adjusting it to fit the system's screen size and limits.
While researching, I found a helpful video that demonstrated a similar approach. If this works, I could explore the archives of old CRT TVs or early system source codes to understand their scanning methods.
Once I determine where the dots land, I'll focus on projecting different colors or mixtures using an RGB LED approach. However, that's a later step.
To simulate the process and test code changes in real-time, I'll use the command line as my simulation monitor, controlling the cursor like the galvo's position to replicate dot placement. This approach is reminiscent of early programming exercises, like drawing shapes on the screen.
After completing these steps, I can address issues like refresh rates, FPS, and the time delay for dots to remain in position before moving.
Lastly, I want this project to be portable so I can experiment outside the lab. This means creating a portable optical table, similar to the one in my lab, by using CNC to drill holes and threads to secure the components. Achieving proper beam alignment is challenging, and moving the project to another optical table could complicate things.
I decided to go with this galvo set for a few reasons
After looking into the galvos a bit, the inner construction of each galvo was found to be very simple. Comprised of two coils on opposite ends, the shaft of the mirror having permanent magnet on it. Some feedback ciruitry, usually light detecting diodes that will change it's value depending on the mirror. Providing it information about the direction it's travelling and the current position.
The galvos work with a differential signal of 15V (so -15V to +15V) capable of detecting millivolts fluctuation and there about (I'm not really sure about this claim).
The driver board is there to take care of the nitty-gritty of the galvo, it's feedback, making sure it is where we want it to be. Keeping account of the inertia of the mirrors, sweeping up an angle at different speeds, staying locked in at an angle are all parts of the functions offered by the driver board. It has two identical blocks of circuitry on the PCB, one for X axis control the other for Y. the rest of the connectors are for input of +15 and -15 so that the galvo will receive this signal. And the inputs for the DAC signal.
The board requires an analog signal as per my knowledge. For that, the STM32F3 discovery board offers DAC (Digital to analog) peripheral. This is a 12 bit dual system perfect for controlling both X and Y. capable of driving them simultaneously with the help of DMA (Direct memory access), more on these terms later. This allows us to vary the analog signal between 0 - 4069 values. However, it seems like this is still not a differential signal because it goes from 0 - +3.3V with that many steps. I believe the driver board itself will be responsible for generation a differential signal from this? Or would we have to provide. I still have to figure this out.
The Galvo's seem to be very straight forward. After contacting the manufacturer and doing some testing on my own i couldn't figure out the connectors on the board and what they do, luckily I found multiple projects where people used the same galvo. but amongst them all this detailed https://hackaday.io/project/165977-laser-galvo-clock/log/164901-frame-driver-schematics article proved to be most helpful. I realised the board i had accepted a signal of +-5V max by finding a listing on amazon of the same board.
A problem soon arose because the board needed a bipolar signal (+-5V) instead of the usual (0-5V). I found out that using a combination of 2 opamps in a certain configuration helps you amplify the signal i was providing (0-3.3V) to (0-5V) and it would add a dc offset to the signal; where usually the signal is offset from 0V now i would get the signal offset from -5V this would create a range of 10. The board then takes that voltage and converts it to appropriate +-15V for the galvo, while also adding in feedback and driving mechanism into the signal to make sure that the mirror is oriented according to the signal.
I didn't know much about opamps and even after https://www.ti.com/lit/an/sloa097/sloa097.pdf up on it a bit and copying the circuit provided in the article i couldn't make sense of this application so decided to not use it and postpone it. Had this been successful it would have permitted me to use the full range of the galvo of around 20-25 degrees. But that would also make the calculations difficult and frankly much more time taking.
By not using the bipolar signal and using the galvo's in such a configuration where...
Read more »Let's sit and think about the number of instruments i have to automate and the data that i actually need.
Happy to share that i've made some promising progress towards accessing instruments supporting usb with python. I call the project "Instrument Orchestra", Instrument Orchestra is now hosted on GitHub with its own repository. https://github.com/manhoosbilli1/Instrument_Orchestra I've provided a detailed step by step installation guide for first experiment.
I tried about 20 packages and different softwares to access this. thought why reinvent the wheel but none worked and almost no one was using this simple approach of accessing the instrument through serial. having some experience in electronics it was easy setting it up but installing the drivers were a pain.
My setup is going to be a sweet one with me remotely getting data from the instrument. this will allow for long lasting testing sessions even when the lab is closed. only have to have my remote laptop attached to instruments and powered on.
Next step would be integrating all 3 instruments with this software and creating a gui with it. i think a live graph of each instruments data would be nice.
I think the nearest possible application is of an rgb led and how it's able to generate a certain a color. Since i'm using a laser it will be a bit different but i think the conversion factor can be changed. I'll look into the construction of a laser.. how it's driven and find some papers that have attempted to control color of a laser.
Side note: Just figured out why the IR wavelength was showing in the green laser. turns out the pure green lasers are rare and what we get is an IR laser lasing at 1056nm there about. The frequency is then double within the structure which halves the wavelength so we get around 532nm there about green light.
The green laser is usually made of inGan material. but since my diode is an IR one not so sure what it's made of. Here's a proper true green laser. https://ams-osram.com/products/lasers/color-lasers-eel/osram-metal-can-to56-plt5-520b i found a good paper explaining the effects of PWM with this laser. i'll read it see if it will give me some insight into having proper pwm control with the laser.
Interesting facts gathered from this paper.
i'll collect each lasers wavelength using spectrometer for CIE coordinates gamut. i'll also measure each lasers optical power with change in voltage/pwm.
I've found that most instruments have usbtcm connection which will let us talk to the device and gather data programatically. i'll try to set that up because when the new lasers arrive i have to be able to get the data fast. even right now i have to measure, wavelength, voltage, current, pwm value, intensity and so on.. will be hard to get 1024 (10bit) data
Found the reason why my eyes were straining. will explain after i explain the spectroscopy.
Since my project revolves around changing and understanding CIE coordinates of colors and converting those values to appropriate pwm signal for the lasers to result in a desired color, i had to find the exact wavelengths of lasers that i was using in order to get a gamut (region of colour space with all the colours available).
For this i used a USB2000+ spectrometer from Ocean optics. a spectrometer basically tells you where the incident light lies on the wavelength scale and what the intensity or saturation is. I first tested with green laser. It was being problematic at first and showing multiple peaks which made us conclude that the laser needs to be exactly pointing to the slit, a slight deviation would result in multiple peaks. but even after adjusting it a multiple times we couldn't get rid of an IR peak at around 800nm which shouldn't be there.. it wasn't there with other lights.. just with this laser. It seems that the peak needs not be clipped for an accurate measurement, instead it needs to be smooth with no sharp edges. this can be fixed by reducing the intensity of the laser. i put an optical diffuser (sort of a lens that dims down light) in between the path of light and reduced the duty cycle of the laser to a value of 30 to get good results. So i got the following result from data captured with the spectrometer.
We can ignore the rest and focus on the fact that at 528.455nm it was showing the highest saturation. Checking that it indeed was giving the write results i searched and it is indeed.
setting the usb2000+ inline with the beam was hard, the optical table did not have holes where i wanted them.. so i used a railing to put everything on it inline.. i then only had to change the vertical axis to bring it inline with the beam. I wonder now whether light transmission was supposed to be done with an appropriate fiber optic cable? I checked in the lab we had a fiber optic but no way to align the lasers small beam to fiber's small core. I wish i had sort of a collector for the light like a funnel.
Next i have to find a way to generate PWM signal of the three lasers combined to result in a specific CIE coordinate. of course i'll start with one colour first. say different shades of green will have different CIE coordinates and that can be achieved with pwm duty cycle? i'm not sure gotta check.
I tested the PWM with a green laser using a 2N2222 transistor between it and the microcontroller. At 1 kHz, the laser did not turn on, but it did at higher frequencies. When I tested it at 10 kHz, it worked, so I guess my theory that frequency wouldn't make a difference was wrong. I wonder if a MOSFET would behave differently—I'll give it a try.
Green Laser:
For further testing, I need an easier way to control the PWM signal. Right now, I'm re-uploading the program repeatedly with different values. I think using a potentiometer to map to the ARR value might work.
P.S.: Although this laser is common and weak, I still feel my eyes straining when working near it. It seems that 6V at 350mA equals 2W, which is not exactly common. Never mind—I found some glasses and will wear them from now on. Haha!
A Question: Can I set the CCR to a value between 0 and 100 to correspond to the duty cycle?
No, the CCR can be set from 0 to the value of ARR. In the case of an ARR value of 1000, CCR can range from 0 to 1000. The CCR is used to control the duty cycle, and this value is compared with the ARR value to generate a certain duty cycle DD.
